Vacuum Hose Fitting
Obsidian Black C43, Silver C43, Silver Carlsson E-class wagon, Brabus G-class
Vacuum Hose Fitting
I'm trying to find a hose fitting that grabs onto a hose next to the MAF. Anyone know where I can buy a new fitting other than the dealership? I'm not sure what the hose is for, but the other end is connected toward the firewall.
Any info would be greatly appreciated.
00 C200 & 00 C55 & 06 SLK55
*In pic. #1: there are a repair kit comes separately:
1) Pin connector for the Vacuum line #: "003 997 02 86"
2) Round connector piece to hold the Vacuum line #: "111 141 00 81"
3) Inner connector piece to hold the Vacuum line #: "111 141 02 42"
4) Seal O-Ring #: "111 997 05 45"
*In pic. #2: this connector is only comes with the Vacuum line assembly......!!
ZAYED,,
ZAYED,,
Any idea how to remove the part 1111410081 ? I've tried everything and can't seem to get it out. There must be a trick. It's part 23 on the attached pic.
After 4 hours, I got all the old plastic parts out by prying each side slowly. Hopefully, the installation of new parts would be less painful.
I had to cut the pieces inside and pry them out slowly. I picked-up the new parts from the dealership, but they don't fit. I think somehow, my car needs different parts for the fitting. The fitting is much bigger (see picture). This is on my C43. I even gave the VIN to the dealership, but yet still the wrong parts. So back to the dealership tomorrow.
That’s strange..!!, i can positively confirm tha part #s are correct...!,, i got the all parts in my hand, but i didn’t put them yet,, is that pic. from your C43...??!!
ZAYED,,
ZAYED,,
The picture is from another forum, but it basically shows how the fitting looks like and it definitely looks different from the parts I have using the part numbers you posted. I even verified it with VIN number at another dealership. It's probably just different version.
All MB M112 & m113 shared the same basic vacuum parts i posted,, i don’t know why the Dealer not clarify that to you....?!?,,
is that forum shows how to fixing them....??
ZAYED,,
ZAYED,,
I figured out what's wrong with the fitting parts shown on the drawing. There's another adapter that goes into the engine side of the intake fitting. The part that has wing clips is installed on this part that is now shown on the drawing. I even inquired with a veteran tech and he didn't know either. Somehow, Mercedes drawing doesn't show this part. Unfortunately, I pulled everything out already so I need to replace the part for sure. Another option is just to use a bunch of different size hoses and hose clamps like someone else did on this forum.
