1998 C43 leather interior color help???
Trying to determine the color of my two tone leather, so I can purchase dye to repair it? Some say white, ivory, silver,light gray???
It's actually silver in color. I have the same, 'Designo" interior in mine. My wheel is closer to light-grey, although I've seen pictures where it's actually silver, or at least silver-ish.
But like Benzslo says, good luck finding a dye that matches. Most upholstery shops I've contacted here in the states can't even get leather in silver, which probably means they can't find a dye in that color. You might have better luck checking eBay.de or other euro sites.
http://www.leatherworldtech.com/Merc...ors-s/1857.htm
http://www.leatherique.com/oem-color...edes-benz.html
http://www.docstotalpackage.net/prod...-Mercedes-Benz
Also read around that you might be able to find it under the name of "designo silver" by this company for a special order: http://www.dynamixdyes.com/
However, I don't know if I'd spend a ton of money on this. There is a whole process on leather tannery you can learn about and I suspect even two tanneries using the same materials can produce different results based on method.
