Spacers for Sedan's
Spacers for Sedan's
Hey guys, anyone using spacers on stock wheels on their sedans? If so, what are you using and what do you think looks best to help give the rear a bit more aggressive look to it to help make up for the rather aneimic quarter panels compared to the coupes?
Thanks in advance!
Thanks in advance!
Can anyone tell me what length lug bolts you used with 15mm spacers? I know the bolts are M14 x1.5, and I *think* the factory length is 27mm, so I'm guessing 42mm, but if someone could confirm I'd appreciate it.
my H&H spacer kit specs says 40mm. Google 1454002 spacer kit for more info
nobbyv (05-08-2017)
I round up and go with 45mm. That is what I did. Check out 42draftdesigns.com spacers. I think they are better made/designed than the H&R and cheaper.
blaferty (06-05-2017)
Thanks in advance!
Thanks in advance!
2 questions:
1. Can you put 10mm h&r spacers (#2055665) on? H&r guide shows minimum hub height of 9mm for 10mm spacer and 10mm hub height for 12mm spacer (no hub height requirement for 15mm spacer installed currently). Anyone have these or have done measurements before I jack car back up and measure?
2. How do you think my 15mm spacers look? Can’t decide if too far out or not.
Very dirty, I know! Cold out, due for driveway wash today.
Thanks!!
Thanks in advance!
Thanks in advance!
this is what I'm trying to decide on, just ordered springs and i'm running 255/275 tires. I'm leaning toward this suggested 15f/12r given my setup. Anyone have any differing opinions?
SPONSOR
We offer competitively priced spacers designed on the w205 c63. All of our kits come with the correct lug bolts as well.
https://modal.works/shop/wheelspacers
we have had a few users run 17.5f and 12.5r on sedans. It really depends on how low you want to go so it’s hard to give a concrete recommendation without measuring directly.
