C63 AMG (W204) 2008 - 2015
Aftermarket wheel Thread.
Old Jul 22, 2015 | 12:19 PM
  #2151
Kriston's Avatar
C63 AMG
Just one more close up pic.
Old Jul 22, 2015 | 12:45 PM
  #2152
Dazzagt's Avatar
C63 AMG - PP+
Cracking Pins !
Wheels are OK too I suppose
Old Jul 23, 2015 | 05:25 PM
  #2153
justinc63's Avatar
C63 AMG Coupe
Brabus Monoblock F 19 x 8.5 & 19 x 9.5 Michelin Pilot Super Sports
Old Jul 23, 2015 | 05:58 PM
  #2154
AlbertWB's Avatar
PREMIUM SPONSOR
Suzuki GSX-R
Common a couple more lol
Old Jul 25, 2015 | 11:13 PM
  #2155
DAMSRT6's Avatar
Mercedes E550 (Previous 450SL, CLK320, C63, SRT6)
TSW Nurburgring 20x10, 20x8.5
I'm still on the fence about these. I might sell them in favor of something a little smaller.
Old Jul 26, 2015 | 12:33 PM
  #2156
JeffDL's Avatar
C63
still might swap out my CH-R for a set of VFF-103s.
Aftermarket wheel Thread.-a52e83f7-c68e-4f93-8f07-2bf3f3ef9255_zpsqpf8ypxf.jpg
Old Jul 30, 2015 | 06:58 PM
  #2157
Nick Ruggiero's Avatar
2008 c63 amg
Little help
Just bought a 08 63 need a little help bc my fifteen52 6k 3 piece tarmacs (pissed) won't fit so what specs am I looking at for some wheels on this thing?!?!
Only pic I had those wheels on my old car 😔
Old Jul 30, 2015 | 07:31 PM
  #2158
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
^^ Try to get for the front:
19x8.5 or 19x9 offset from +40 to +45
For the rear:
19x9.5 or 19x10 offset from +45 to +55
Old Aug 31, 2015 | 03:01 PM
  #2159
HTX C63's Avatar
2009 c63
ADV15 Tack Funtion SL
Old Sep 16, 2015 | 01:52 AM
  #2160
quickersol's Avatar
2009 C63
20x8.5 and 20x10 Gianelle Monaco
First post, I usually read and find the answer but am still unsure of this one... here are the specs:
2009 C63
20x8.5 Gianelle Monaco ET39
20x10 Gianelle Monaco ET46
225/30R20
275/25R20
H&R springs
Will it rub? From what I've read so far (which took like 6 hours lol), front seem OK. Back seem mighty close. Any other issues when running these wheels? Would a different tire size help? Seems like there are not many in this size range.
Thanks in advance!
Here is the wheel I'm refering to in the custom finish of Matte black with white flange and matte black bolts
My C63 and E55... the C63 has a set of spare E55 wheels on it temporarily
Old Sep 16, 2015 | 07:44 AM
  #2161
Roswell's Avatar
The front will work fine, the rear will rub with 275 +46 offset... try 255 or 265 & you will be fine on H&R.
Old Sep 16, 2015 | 06:14 PM
  #2162
Hedges's Avatar
2018 S63 AMG S and 2018 GLS450
That guy in the golf cart is going "Daaaaym"
Old Sep 16, 2015 | 07:46 PM
  #2163
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Which is fine if you like the stretched look and the compromises it brings. Personal style taste over substance. My tyre experts see my 275s as minimum for my 10' rears.
Old Sep 17, 2015 | 09:13 AM
  #2164
JeffDL's Avatar
C63
lol probably more like WTF are you thinking. was like 100 degrees and 100% humidity at an open track day. car was unhappy and hot.
Old Sep 18, 2015 | 10:14 AM
  #2165
Phil Chow's Avatar
W204 C63
Can anybody confirm whether the HRE FF01s will fit without rubbing on 245/35/19 and 275/30/19?
The wheels are:
19x8.5 +47
19x9.5 +45
I'd like to run a 245/35/19 on the Front, and a 275/30/19 on the Rear. Michelin PSS.
Old Sep 18, 2015 | 11:19 AM
  #2166
Mr. Lin's Avatar
2008 C63
I could've sworn that I read someone with those specs said they had to run 265s in the back
Old Sep 18, 2015 | 11:27 AM
  #2167
Girard@ACGautomotive's Avatar
a car
The wheels are:
19x8.5 +47
19x9.5 +45
They'll rub
you can do a 245 in the front, but a 255 in the rear is seriously as big as you can go on a michelin pss.
Old Sep 18, 2015 | 07:04 PM
  #2168
Roswell's Avatar
^^ I agree, 19x9.5 +45 is aggressive .. 255 would be safe, 265 might work depending on the tire brands.
Old Sep 18, 2015 | 11:30 PM
  #2169
Phil Chow's Avatar
W204 C63
Well, guess that rules out the HRE FF01s then. Will need something that I can dial in custom widths and offsets!
I prefer a 19x9/19x10 setup anyways!
Old Sep 20, 2015 | 05:15 AM
  #2170
Phil Chow's Avatar
W204 C63
Can anybody confirm the "best" fitment for a 19x10 to run a 275/30/19 Michelin PSS in the rear, along with being lowered is?
From what I gather, it's something like 19x10 +55?
Old Sep 20, 2015 | 11:18 AM
  #2171
Roswell's Avatar
19x10 +55 is safe but not flush enough.
I'm running 19x10 +50 with 275/30/19 PSS lowered on H&R springs with thicker rear pads (17mm) no problem even with passengers in the rear. I will occasionally rub with passengers over big bumps though.
So it all depends on ur rubbing tolerance. Go +55 if u want 0 rubbing , go +50 if u want flushness &/or rarely carry rear passengers.
Old Sep 20, 2015 | 12:02 PM
  #2172
Phil Chow's Avatar
W204 C63
There's a set of Forgestar CF10s that I'm looking at. They're +52 offset, but I reckon I could take 3MM off the backpad and make them +55 if I really wanted them to.
Does the 19x10 +55 clear the inner strut and inner fender liner? Will it rub from the inside?
My rubbing tolerance is 0, haha. On a car that I plan on driving hard, I want 0 rubbing, otherwise it irks me, lmao.
Old Sep 20, 2015 | 12:27 PM
  #2173
Roswell's Avatar
At +52mm, u don't need to shave 3mm to make them +55mm. U should clear no problem as is.
Old Sep 20, 2015 | 12:30 PM
  #2174
Mort's Avatar
It is difficult to pin it down exactly when you are running tolerances this tight. I am running 19 x 10 ET +52 with MPSS 265/30/19 on my 2012 with KWV3 lowered all the way (~.75") and it rubs the fender joiner every now and then. Just a snick but a rub all the same and no rear passengers. I ran the same wheels on my 2010 lowered on H&R springs (~.75") and was able to run MPSS 275/30/19. I think you should be OK on the inner fender at ET+55. Keep an eye on the lines running to the fuel tank as they protrude the most into the inner fender area (right rear ahead of the axle).
Old Sep 20, 2015 | 01:11 PM
  #2175
Roswell's Avatar
Mort, I find it strange that u can run the same wheels with 275 on ur pre-FL car no problem.. But u get slight rubbing with the same wheels on 265 with ur FL car.
Ride height & stiffness must play a role.
