Performed Service B myself, few pictures and questions
2017 Mini Cooper S Clubman ALL4 - British Racing Green
So, I did the Service B, followed the checklist that I got from my dealership.
Replaced the Air Filters, changed the oil/filter (pulled out about 7.5 qts via the pump method, picked up the pump from West Marine), put about 8 back in. Checked all the hoses, lines, etc etc.
Came across this, the steering side is fine, the rear however is a different story, took these two pics of the boots over the drive axle.. They appear to be decaying or rotting.. Anyone else noticed this on their vehicles, I may take a trip to my dealer to have them fix it before they completely fail, as its not something I can do myself...
Looks to me to be some sort of undercoating that was sprayed and got on the boots. After time it dries out and cannot stick to the rubber, with all the flexing it goes through and flakes off. I have just carefully flaked it off and if the rubber is still good underneath then you should be good to go.
Most boots I have seen that start to degrade from age seem to form craze split lines in the rubber that run around the diameter of the boot in the peaks and valleys and not across the length. I don't think the rubber will flake off like that.
Not saying you should not get someone to look at them, just that I have seen a lot that look like that and it was a protective product that was peeling off the surface of the boot.
2010 Irridium Silver MB C63 AMG Sedan
02 CLK 55 AMG,09 C63 loaded with P30
'15 E63S wagon
B/C it's a pain in the a$$, filter installs from the top, and oil extractor from the top works great. 0.5q of old oil still inside isn't the end of the world in a 9q capacity engine IMO; different story if it was a 4q pan.
C63AMG, NIssan NX2000, Pontiac Fiero GT
Drain the oil with the plug out. Hoist the beast on blocks to get crawl space. Leave the wheels on. I use big cat litter container. Cut the top out , voila catch tank for 9 qts. Drain it at least warm. You guys with lifts are really spoiled (green , green envy)
That remaining oil on the bottom of the oil pan is what it has the most dirt. When I use to do oil changes on other cars I would also let it drain for a few minutes. It is just a matter of preferences.
This is nothing, it's simply the paint, that's flaking off. If the boots were actually torn, you would see lubricration leaking out. Also I like to use the drain method instead of the suction method for removing oil. As the car holds roughly 9.3 qts, and you only managed to remove 7.5 qts. I also drain the oil cooler, that holds about a cup full of oil. But to each his own.
The only issue, that I see with suction is that you can't extract all the oil out. The bottom line is this, one can never get all the oil out. But draining it extracts more oil then sucking it out. And I'm not the only one, here that shares this view.
No, I do not disagree with you, which is why I alternate, but 7 to 8 of new with 1 to 2 old is not going to be too much of an issue between the drain from bottom method.. especially since I do my oil every 5k miles instead of every 10k
