Guys with H&R Sport Springs, What the ride quality like????
AMG GTS
Hi Guys,
Looking to go with H&R lowering springs, any drastic changes in ride quality?
I dont have the p30 option so as long as the ride stays similar what it is now i would want to see it little but lowered.
Thanks!
Thanks!
I love the look of my H&R drop, and I find the car handling has improved. The ride is a little stiffer than stock, but nothing drastic.
AMG GTS
You guys are the best!! Thanks for the feedback.
I just picked up a set based on this. Cant wait to get them on.
Next is possibly SS brake lines? anyone go with this?
A few members have SS brake lines.
RPM North and Evosport sell the.
http://rpmnorth.com/products/technaf...b0a0073eed925f
http://www.evosport.com/product/prod...RK.M04.C63.LNS
-BEFORE ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.05
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.07
Total Toe Angle: -0.12
Steer Ahead: 0.01
Left Rear
Camber: -2.1
Toe: 0.38
Rear Right
Camber: -1.6
Toe: 0.22
Total Toe Angle: 0.60
Thrust Angle: 0.08
-AFTER ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.17
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.22
Total Toe Angle: -0.39
Steer Ahead: 0.03
Left Rear
Camber: -2.1
Toe: 0.36
Rear Right
Camber: -1.6
Toe: 0.48
Total Toe Angle:0.84
Thrust Angle: -0.06
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.05
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.07
Steer Ahead: 0.01
Left Rear
Camber: -2.1
Toe: 0.38
Rear Right
Camber: -1.6
Toe: 0.22
Thrust Angle: 0.08
-AFTER ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.17
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.22
Steer Ahead: 0.03
Left Rear
Camber: -2.1
Toe: 0.36
Rear Right
Camber: -1.6
Toe: 0.48
Thrust Angle: -0.06
-BEFORE ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.05
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.07
Steer Ahead: 0.01
Left Rear
Camber: -2.1
Toe: 0.38
Rear Right
Camber: -1.6
Toe: 0.22
Thrust Angle: 0.08
-AFTER ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.17
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.22
Steer Ahead: 0.03
Left Rear
Camber: -2.1
Toe: 0.36
Rear Right
Camber: -1.6
Toe: 0.48
Thrust Angle: -0.06
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.05
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.07
Steer Ahead: 0.01
Left Rear
Camber: -2.1
Toe: 0.38
Rear Right
Camber: -1.6
Toe: 0.22
Thrust Angle: 0.08
-AFTER ALIGNMENT-
(With H&R springs)
Left Front
Camber: -1.9
Caster: 10.8
Toe: -0.17
Right Front
Camber: -1.8
Caster: 11.2
Toe: -0.22
Steer Ahead: 0.03
Left Rear
Camber: -2.1
Toe: 0.36
Rear Right
Camber: -1.6
Toe: 0.48
Thrust Angle: -0.06
Ty for the info.
Thanks AMG for the infos on the alignment... I have yet to do mine since my dealership machine is not working yet (they are on renovation).
As I can see, the H&R drop is very minimal therefore the before & after alignment are very similar specs.
The car was puling very slightly to the right before alignment but nothing major. Just wanted to get the alignment to be on the safe side.
WOW. Absolutely loving those wheels!!
...drop doesn't look like much at all though?
the ride isn't good but the ride on a stock car isn't good. the change really isn't that much.
edit: the drop isn't much H&R states .75" all around.
