C63 AMG (W204) 2008 - 2015
What is the best air filter for c63
Old 12-24-2011, 06:05 PM
Bu-zayed's Avatar
C63 09' p30
Hello guys
I have on my c63 k&n air filter, so im looking which is the best air filter and which air filter give you more hp.
Old 12-24-2011, 07:52 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Stay with stock filters.
Old 12-24-2011, 08:48 PM
Merc63's Avatar
C63 AMG
K&N is one of the best, keep them.
Old 12-24-2011, 08:51 PM
_AMG_'s Avatar
C63
Im currently using K&N's but wasn't expecting any HP gains just wanted to get a little extra air flow.
Ive heard great things about BMC filters and AFE Pro Dry S filters. Might wanna give those a try.
Old 12-24-2011, 09:15 PM
Vabene7's Avatar
Garage Temporarily Empty
I too, have heard great things about K&N filters. I used them in a previous clk of mine. I cannot not honestly say they gave me any HP improvement, but I did notice a slight louder exhaust note. But nothing I could feel.....now I'm using BMC filters which are used in F1 racing.
Same conclusion. I'm sure they flow great, but exactly how much more than stock, I can't say.
Old 12-24-2011, 09:48 PM
peh-amg's Avatar
'13 Audi RS5
Where's the best place to buy BMC or AFE filters from?
Old 12-25-2011, 04:36 AM
Bu-zayed's Avatar
C63 09' p30
Thank you guys
Old 12-25-2011, 04:57 AM
_AMG_'s Avatar
C63
I think Vivid Racing sells BMC filters, might wanna check with them.
You can order AFE filters from www.autopartswarehouse.com
Old 12-25-2011, 10:07 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
AFE filter! The have dry and wet filters, if you have concerns with your MAF. Also the perimeter seal on the AFE does not block off so much of the filter like the KN and is made of poly.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 12-25-2011, 11:09 AM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
I have tried them all. BMC, K&N, AFE. Pipercross is the best and they will give you extra horsepower
Old 12-26-2011, 09:00 AM
Bu-zayed's Avatar
C63 09' p30
What do you. Mean pipecross can you explain for me please
Old 12-26-2011, 11:10 AM
Quadcammer's Avatar
96 and 08 911 turbos
just use the stock one.
Old 12-26-2011, 12:26 PM
track_warrior's Avatar
Like The Stig
I think he means these: http://www.pipercrossusa.com/
They look like a foam filter
I remember seeing this comparison a while ago between cone filters, i know they are not replacement filters but they are made off the same materials.
http://www.mkiv.com/techarticles/filters_test/2/
here is an old thread about it as well
https://mbworld.org/forums/c63-amg-w...ipercross.html
Old 12-26-2011, 01:02 PM
jacob502's Avatar
Pippersross filters are "spunge like" filters. They will allow the air to flow freely, unlike BMC or K&N, where restriction is reduced but air is still blocked. With pipersross filters Air flows freely while all the unwanted particles are absorbed. These filters will give you 6-8rwhp on the M156 platform.
here is a photo:
comparing a stock panel filter with a Pipercross filter
Old 12-26-2011, 05:44 PM
bhamg's Avatar
C63 AMG
I've never understood the logic behind claims like this. Perhaps it could be true true if the filtering media were much, much thicker (meaning inches thicker) but with these shallow filters how can all the particulates be trapped while the filter flows more freely? It just doesn't make sense on any level but maybe I'm just missing something here...
Old 12-26-2011, 06:04 PM
jacob502's Avatar
the answer is easy. Try out each filter (obviously you havent), have a dyno run on all filters, and you will know for sure.
The stock panel filter are made from paper material, while pipercross maintain a foam material.
Gtsman (04-08-2018)
Old 12-26-2011, 10:32 PM
bhamg's Avatar
C63 AMG
I'm not worried about the "making more power" thing...if it flows better there might be more power...it's the bolded that makes NO sense whatsoever if the former is true..
Old 01-05-2012, 02:29 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Careful guys. There is a vast literature out there on paper vs other media air filters. Paper is superior in trapping dirt and adequate in all but racing. Believe it or not the best paper found in the summary I read was AC Delco, as in Chevrolet...I imagine MB knows ... Don't know of any factory issue foam or oiled media filters. No stones please.
Old 01-06-2012, 03:47 AM
derspi's Avatar
2009 C63
Stock filters are fine. I gave up on aftermarket drop-in filters a LONG time ago. Save your $ and frustration with possibly triggering CELs because you over-oiled the damn thing after cleaning it and ruining your MAF sensor (yes, been there, done that & so have many others before me). It's just not worth the hassle.
Old 01-06-2012, 09:14 AM
jboogie's Avatar
C63 Coupe
Should I bother taking out the charcoal??
Old 01-06-2012, 11:53 AM
bhamg's Avatar
C63 AMG
If you feel like spending a little extra money IMO you should pair the ROW air boxes with OE paper filters.
Old 01-06-2012, 01:31 PM
tmldds's Avatar
2010 C63, 2009 S550, 2007 GL450
What for? To go a tiny little bit faster?
Old 01-06-2012, 01:48 PM
bhamg's Avatar
C63 AMG
Yup.
Old 01-06-2012, 03:15 PM
604 C63's Avatar
2012 E550 Cabrio
If you cant tell the difference between any of those filters, either your @$$ is way more sensitive than mine or you are hallucinating.
Old 01-07-2012, 07:41 AM
derspi's Avatar
2009 C63
Nope, wouldn't bother with that either but that's just me.
Quick Reply: What is the best air filter for c63
