C63 AMG (W204) 2008 - 2015
Any DIY for removing MAF's?
Old 01-21-2012, 11:49 AM
peh-amg's Avatar
'13 Audi RS5
Anyone have a DIY or instructions for removing MAF's? I'm having trouble figuring out how to disconnect the electrical connection (don't want to break it) and also remove the two steel clips that hold the MAF's in place.
Old 01-21-2012, 02:23 PM
Merc63's Avatar
C63 AMG
Why are u removing them? I remember they are hard to get out. I have to force it with a small screw driver.
Old 01-21-2012, 02:32 PM
peh-amg's Avatar
'13 Audi RS5
I want to clean them.
RyRico (07-03-2023)
Old 01-21-2012, 03:54 PM
Merc63's Avatar
C63 AMG
Id just leave them alone, unless they needed to be cleaned...But your car is brand new.
Old 01-21-2012, 04:58 PM
peh-amg's Avatar
'13 Audi RS5
I've been getting a hesitation/misfire but no CEL and I've got K&N's so thought I would clean them. I just removed the airbox lid, left the MAF's mounted and sprayed them with CRC MAF cleaner. I'll see if this helps.
FYI - car doesn't throw a CEL so my dealer has no idea what to do. Car hestitates when cold.
Old 01-21-2012, 05:53 PM
Merc63's Avatar
C63 AMG
Lol its so funny, they can't fix anything unless the computer tells them what is wrong.. I guess that's what we get for relying on electronics to control everything...
I have heard of the oil from the K&Ns coating the MAFs. Did cleaning them fix it?
Have you checked your plugs?
Old 01-21-2012, 09:05 PM
peh-amg's Avatar
'13 Audi RS5
Diagnostics came up clean at the dealer so they have no clue what to do or where to look now. They are waiting for direction from MB!
I cleaned the MAF's and it didn't fix the problem. Only happens when the engine is cold - maybe I should check plugs next but I've only got 2800 miles on the car. Maybe 02 sensors?
Old 01-21-2012, 11:03 PM
Harold1898's Avatar
2015 E400 Coupe
Surely that is a warranty issue and the dealer has to fix it by law.
Old 01-21-2012, 11:29 PM
Merc63's Avatar
C63 AMG
Misfires/hesitations, check the plugs, turn the car on let it run till it misfires then turn it off. Pull the plugs and check them out.
Old 01-22-2012, 12:22 AM
peh-amg's Avatar
'13 Audi RS5
Sure, it is covered by warranty and it's going back to the dealer on Monday but they don't see any CEL's so they are not sure what to do or where to look. My SA said they do not have a clear idea of what to do next..My dealer has been good prior to this but they aren't exactly falling over themselves to try to fix this. I agree it's not a serious problem but it is very annoying.
Old 01-22-2012, 12:23 AM
peh-amg's Avatar
'13 Audi RS5
It's gong back to the dealer on Monday so I'll ask them to do this. Hope they do it!
Old 01-22-2012, 01:03 AM
Merc63's Avatar
C63 AMG
They won't do **** unless there's a CEL.
Old 01-22-2012, 11:36 AM
peh-amg's Avatar
'13 Audi RS5
Sadly, I think you are right.
Old 01-22-2012, 12:47 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Did u remove your charcoal filters, if so just for kicks and giggles put them back in with ur kn filters and see is the hesitation is gone... We have seen this a few times with the charcoals removed.
Old 01-22-2012, 12:50 PM
MBfinatic's Avatar
e36 318i, 2004 sti
I always wipe down the K&N filters. Not until they are dry but to get a good amount of excess off.
Old 01-22-2012, 01:25 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
easy to remove....
1)Take off the silver cover on the top.
2) Remove the 2 screw holding it in
3) Jiggle and pull them out.
4) To clean them use sensor safe MAF cleaner.
5) Air dry COMPLETELY
6) replace
NOTE: remember which way they go in/face and which one was for which side.
Hope that helps
Old 01-22-2012, 06:38 PM
peh-amg's Avatar
'13 Audi RS5
Previous owner removed the charcoals and put K&N's in. Probably worth a try to put charcoals back in but why would the hesitation only happen when the engine is cold? Runs fine when the engine is up to temp.
Old 01-22-2012, 07:04 PM
peh-amg's Avatar
'13 Audi RS5
I took the K&N's out yesterday and wiped any excess oil off them and cleaned the MAF's - didn't fix the problem unfortunately.
Quick Reply: Any DIY for removing MAF's?
