Glossy or Matte?
C63 Edition 1 Coupe
Glossy or Matte?
Planning on getting my window trim vinyl wrapped kind of stuck on matte or glossy, opinions and input welcome. Thanks
I think this essentially depends on how do you want it look like. I'd say if you want a contrast you should go with gloss or if you the trims to blend in, then definitely matte or satin. Hope this helps.
I think it looks good in chrome as it matches the lip on the wheels. (Your car looks great as is haha) If you're planning on blacking out everything then I would go matte.
ps. Im a huge fan of the rear on the brabus.
C63 Edition 1 Coupe
Thank you everyone for the input I'm still pretty stuck, I'm considering doing the grill also if this is the case does that change people opinions such as should they be the same or can they be different?
[QUOTE=N1ck;5027743][url]http://www.rpmgo.com/cars/main.php?g2_view=keyalbum.KeywordAlbum&g2_keyword= Geneva&g2_itemId=13633]
Thanks but I can't really tell which one it is, but it's matte correct?
[quote=C63coupe;5027950]Thank you everyone for the input I'm still pretty stuck, I'm considering doing the grill also if this is the case does that change people opinions such as should they be the same or can they be different?
Since you mentioned it and I had taking a look closer to it, I'm not really sure now.... The pillars are in matte and the trims are probably in regular gloss black would be my guess because they give that shine in the light.
