C63 AMG (W204) 2008 - 2015
Recommend me a spark plug
Old 07-18-2012, 07:53 PM
linjy2's Avatar
C63
So I'm at 60k miles now and I want to replace my spark plugs.
Which one should I buy? Stick with OEM?
Does anyone have the partnum? So I can buy it online for cheaper?
Old 07-18-2012, 07:57 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Go OEM
https://mbworld.org/forums/w211-amg/...ark-plugs.html
The NGK part number is listed in your owners manual. It is not an MB part number.
Old 07-18-2012, 08:03 PM
linjy2's Avatar
C63
Thanks for the DIY, what about a good place to buy them? Or local stealership?
Old 07-18-2012, 11:48 PM
type in the number into google shopping. You should get plenty of choices.
Old 07-18-2012, 11:53 PM
COBRA63's Avatar
C63
Originally Posted by Jon2007E63P30
Go OEM
+1
you can buy them from parts.com
you should be able to recieve them within four days!
Old 07-19-2012, 12:01 AM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Go OEM
Awesome write up. Subscribed to the thread.
Most auto parts store should carry NGK spark plugs. NGK plugs are well engineered and made IMO.
Old 07-19-2012, 12:21 AM
Well I am posting this because although I am a big proponent of RTM (=Read The Manual), I was looking at a 2011 E Manual with no mention of the NGK part number. So no mor eholding out.
NGK’s ILZKAR7A10 iridium spark plug has been chosen for OE fitment to the 365kW, 6.3-litre V8 power unit developed by AMG for use in high-performance derivatives of Mercedes models. In this case, the main requirement was for the slimmest possible spark plug with sufficient performance, in order to leave as much space as possible in the cylinder heads for both valves and coolant passages. To satisfy this need, NGK developed this new plug with a 12mm thread, but a 14mm hexagon and a slimmer ceramic insulator. The length remains 26.5mm.
Old 07-19-2012, 09:35 AM
Merc63's Avatar
C63 AMG
I went with Brisk plugs. Weistec uses them.
Old 07-19-2012, 12:38 PM
BO Knows's Avatar
2010 C63, 2007 X5
+1 http://www.weistec.com/m156spark.html
Old 07-19-2012, 03:45 PM
linjy2's Avatar
C63
Originally Posted by BO Knows
I just ordered this!
Was thinking about going stock but figure I give these a try.
going to gap them at .040
Old 07-20-2012, 01:33 AM
BO Knows's Avatar
2010 C63, 2007 X5
Make sure you keep us all posted about the results
Old 07-20-2012, 06:44 AM
Even Money's Avatar
'15 VW GTI
you guys running these colder plugs on stock set ups??
Old 07-20-2012, 08:01 PM
+1. Why?
Old 07-20-2012, 09:34 PM
Even Money's Avatar
'15 VW GTI
+1. Why?
Colder plugs aren't really needed unless you have headers or a blower. IDK, but maybe you lose some power on a stock setup, or more chance of a fouled plug?? The colder plug is to prevent pre ignition in a more robust environment from the power adder.
Old 07-21-2012, 12:31 AM
linjy2's Avatar
C63
Well I have a tune and cat/res delete. I recently had a cel. I didn't pull the code but went away on restart. So I assume it's a misfire.
With the way I drive this car in Houston 100+ heat I guess colder plugs should be ok.
Old 04-06-2013, 09:26 AM
c63philly's Avatar
c63
how is the plug working out for you
Old 04-06-2013, 11:57 PM
tfthach13's Avatar
'09 C63
I don't think the OP install them. There's another thread of him/her selling them.
Old 04-08-2013, 06:59 AM
Mikegpr03's Avatar
C63
Thank you for the write up!
I went ahead and did my plugs with your thread. I used OEM plugs and car car does feel snappier. Thank you again. FYI I ordered green filters and plan on heading to the Dyno soon for some numbers.
Quick Reply: Recommend me a spark plug
