C63 AMG (W204) 2008 - 2015
Ethanol Gasoline Warning to Consumers
Old 12-31-2012, 08:59 AM
G55AMG's Avatar
2008 G55, 2012 C63 BS
http://video.foxbusiness.com/v/2000862202001/
Mercedes will void your warranty if you use ethanol 15 gas
Old 12-31-2012, 12:29 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Saw that on the PL. We should use this as an opportunity to contact our Senators and Congressmen about the harms and uselessness of ethanol. There is no benefit except to lobbyists and corn farmers.
Old 12-31-2012, 01:23 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
I've been running E85 in my Evo for years now and it's only a 2005.
Old 12-31-2012, 10:49 PM
roadtalontsi's Avatar
10 C six trizzle
lol nothing like race gas for 3$/gal.
Old 01-02-2013, 11:38 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
MB cannot void the warranty no matter what they say, if all pumps in the US moved to E15 (edit: originally said E85, meant to say E15) there is no other option, they cannot arbitrarily void the warranty. That of course is a long way off, so hopefully the issue won't happen anytime soon.
Old 01-02-2013, 12:03 PM
rage2's Avatar
C63 BS, GLA45
Sure they can. It says specifically in the manual, under Fuel requirements, that Ethanol can not exceed 10%. If you don't follow the manual, you void your warranty.
Old 01-02-2013, 12:34 PM
Exactly haha
Old 01-02-2013, 12:44 PM
Thrilla's Avatar
2014 C63 AMG 507 sedan
Exactly haha
Truth!
Old 01-02-2013, 02:02 PM
b16
b16's Avatar
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
Ran it on my 2005 Evo for about 100,000 miles. Love the stuff.
My Honda race car which is a 1994 also runs on E85 full time.
Like others have said, super cheap race fuel.
Old 01-02-2013, 03:21 PM
rage2's Avatar
C63 BS, GLA45
E85 is awesome if you can tune for it.
Old 01-02-2013, 03:32 PM
looney100's Avatar
None
...and your fuel system is compatible.
Some are incompatible with high levels of ethanol.
Old 01-02-2013, 04:22 PM
That's precisely the argument in the article. They don't really mention any engine concerns. It's the fuel lines, seals, etc that can be damaged.
Old 01-02-2013, 05:16 PM
moosejaw's Avatar
none
Dont let ethanol sit too long
Gums up real bad esp in the deep south.
Needs to be driven daily
A lot of FDs i know converted back to c16
ID 1000cc Injectors arent cheap.
Old 01-02-2013, 06:22 PM
b16
b16's Avatar
I have yet to see a real world example of Ethanol damaging fuel lines. People are selling wolf tickets.
My experience with it is some batches created a black tar like substance at the injector tip that was easily cleaned off. Even my 1994 Honda fuel system handles it (albeit with upgraded pump and injectors to keep up with fueling demands). And it sits up to 6 months at a time.
Old 01-02-2013, 06:52 PM
There are a bunch of cases where ethanol is expanding the composite gas tanks of Ducatis.
Old 01-03-2013, 06:58 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
On a side note, in my 07 Audi manual it states:
"The use of E15 or higher will damage the engine and is not covered under warrenty"
Just saying
Old 01-03-2013, 11:03 AM
jvanbrecht's Avatar
Just talk to boat owners.. there is a reason why Marinas sell 100% gasoline, no Ethanol at all..
Ethanol is Hygroscopic, it attracts and holds onto moisture, which is far more prevalent on coastal and lake regions, and can cause major damage to engines. Obviously, cars are less likely to have moisture in the fuel lines, but its not impossible.
Seals in general, unless silicon based, get destroyed by Ethanol. Alcohol turns plastics and rubber brittle. That is the primary problem.
Old 01-03-2013, 11:24 AM
moosejaw's Avatar
none
Correct but see below. Ive seen this black substance build up in intake manifolds in FDs. I wont go E85. Try cleaning those same injector tips on a Rotary, Supra or hell even a MR2 turbo. I wouldnt look forward to that kind of maintenace
Oh man so true, i wish we could get straight gasoline in my neck of the woods
Couldnt have said it better myself. Well done.
Old 01-04-2013, 09:40 PM
C63newdude's Avatar
C63 AMG
Running E-85 on my Evo and STI and no problem.
Old 01-04-2013, 11:24 PM
b16
b16's Avatar
Exactly. The naysayers have 0 personal experience with the stuff. It has always been that way.
Old 01-06-2013, 02:51 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
I think it's been shown that all up ethanol is not cost effective, only lobby effective.
NOW HEAR THIS, NOW HEAR THIS... a few years back the EPA gwarranteed the no manufacturer could sell equipment susceptible to ethanol fuel degradation. (not a joke).
In a parallel universe my tractor friends have told me that townships of 5K and lower can still sell ethanol free fuel. and that an online ( I think) listing is available. I have not pursued. Repair facilities still report swollen viton carb parts and heavy deposit which clog fuel systems, but that may be on
?pre 98? stuff.
A gallon of ethanol gas can absorb about 4 teaspoons of water. Beyond that the water and some ethanol ride along with the mixed fuel as fellow travellers which the EPA admits can affect idle. See Wikepedia for more reading pleasure.
Old 01-06-2013, 06:11 PM
bhamg's Avatar
C63 AMG
Yeah, a massive special interests ripoff. Isn't the true cost of a gallon of ethanol (i.e., total direct and indirect costs) something around $8.00/gallon?
Quick Reply: Ethanol Gasoline Warning to Consumers
