C63 AMG (W204) 2008 - 2015
Weistec Stage 3 build w/ replacing head bolts thread.
Old 03-24-2013, 11:52 AM
Merc63's Avatar
C63 AMG
I'm going to record the progress of taking a bone stock C63 to Stage 3 and also replacing the stock head bolts with studs by changing them with the engine in the car one by one.
I'll be snapping pics along the way and updating frequently as we move through the job.
I thought some of you would be interested in the blower install and I know some guys want to see how it goes installing the head studs.
Also might be replacing the lifters (tappets) with the revised ones from the SLS after we examine them once the cams are out of the way.
Old 03-24-2013, 12:07 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Merc, Looking forward. Noticed on Baum Tools site a kit for installing "helicoils" in the block. Is this a problem on the C 63?
Edit: The Baum Kit of helicoils for the block... thought for the day: After blaming the weak headbolts, is some of the problem with coolant in engine due to over torqueing the TTY bolts and pulling block threads? Ironic twist...the TTY bolts do not yield? Just sayin...
Last edited by motoman; 03-24-2013 at 04:27 PM. Reason: add thought about coolant problem
Old 03-24-2013, 12:14 PM
Merc63's Avatar
C63 AMG
Valve body ready for shipment to Weistec for TCU upgrade.
Engine bay
Old 03-24-2013, 01:01 PM
BLACKONBLACKC63's Avatar
c63amg
Good luck with the build and thank you for your dedication.
Old 03-24-2013, 02:33 PM
bhamg's Avatar
C63 AMG
Great stuff...looking forward to this...probably should be stickied in some form too.
Old 03-24-2013, 02:41 PM
SLS Qatar's Avatar
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
Excellet thread. looking forward for some updates. good job
Old 03-24-2013, 02:59 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Only if you strip the treads in the block, I suppose.
Old 03-24-2013, 03:29 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
you're not messing around are you?
Old 03-24-2013, 06:59 PM
Mort's Avatar
Merc good luck with this. I am very interested in how changing the head bolts goes. I am thinking of doing this myself when the warranty expires on mine. Thanks for posting up this info and keeping us in the loop.
Old 03-24-2013, 08:10 PM
blackbenzz's Avatar
haters crazy
Awesome thread! Love it when people diy. I should have taken pics with my car and posted up.
Old 03-24-2013, 10:05 PM
mthis's Avatar
Anything W/4Wheels
Great Cant wait one day ill use this thread .
Is it hard to remove the valve body?
TIA
Old 03-24-2013, 11:28 PM
BRABUS786's Avatar
Stage 3 63
Good luck
Old 03-25-2013, 12:38 AM
Merc63's Avatar
C63 AMG
TIA
Not at all, just some bolts and a connector and it falls out. I believe there is a how to on Weistecs install page.
Thanks for the encouragement everyone.
Spent a few more hours in the garage tonight removing the stock exhaust. This car was winter driven a couple seasons and the exhaust bolts are rusted to ****. I am having a hell of a time getting some of the studs off the exhaust manifolds.. Luckily we have everything off the top of the engine and with the valve covers removed it gives you a lot more room to get tools in there.
I have 3 nuts/studs left on the one log and it will be all off.. going to need to weld up a socket on a bar to get these last ones off unfortunately. I am going to replace them all with new studs and nuts.
Hoping to have the head studs in for next Saturday and start working on that.
Old 03-25-2013, 02:47 AM
layzie12g's Avatar
2008 Mercedes Benz E63
Keep the pictures coming.
Old 03-25-2013, 09:29 AM
Djmouz63's Avatar
2011 C63
Great work cant wait to see this through!!
Old 03-25-2013, 11:07 AM
ed4
ed4's Avatar
2010 Audi S4, 2013 MB C63
* Subscribed *
Old 03-25-2013, 11:26 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Godspeed......
Old 03-25-2013, 11:55 AM
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
I wish I had monies to do this
Old 03-26-2013, 09:21 PM
Merc63's Avatar
C63 AMG
Head studs and plugs are in.
Old 03-26-2013, 09:40 PM
mthis's Avatar
Anything W/4Wheels
If u don't mind taking detailed pix of the head bolt replacement process I would greatly appreciate it.
I'm looking to do everything u doing soon just not soon enough.
TIA
Old 03-26-2013, 10:38 PM
bhamg's Avatar
C63 AMG
This gets my vote as the *awesome* thread of the (still young) 2013.
Old 03-26-2013, 11:29 PM
Merc63's Avatar
C63 AMG
ECU and TCU/Valve body on route to Weistec.
I've chatted with Steve at Weistec about switching the head bolts one by one and have a solid game plan.
The head studs go into the water jacket so they must be sealed with 500F silicone on the top threads, bottom of the nut and washers. The sealing surface must be completely clean of oil (which there is lots of everywhere).
The head bolts are down an opening in the head so oil gets trapped down there.
I'm going to use a metal rod with a cone shaped end to plug the hole where the stud goes, while spraying parts clean all over the sealing surface and sucking it up with my pneumatic extractor. Cleaning with a rag also till it is spotless.
Stay tuned.
Old 03-26-2013, 11:37 PM
CarHopper's Avatar
E63S | X5
ARP studs? Looks like a tedious but rewarding process. Definitely keeping an eye on this.
Old 03-27-2013, 12:34 AM
Merc63's Avatar
C63 AMG
Just did a little calculation for the guys that think the head gasket will be compromised.
With 1 of 10 headbolts removed, you are looking at around 90,000lbs of clamping force from the remaining 9 bolts. That gasket isn't going anywhere
Old 03-27-2013, 09:06 AM
rags260z's Avatar
2011 C63, '78 LS1 280Z, '71 240Zt, '87 Grand National, '01 F150
Love this thread!
I'm all for trying to change the headbolts one by one and would try this myself if my engine had the older style bolts. Without actually seeing a bare head with my own eyes, one thing you mentioned does have me worried. You said the headbolt threaded holes go all the way into the waterjacket in the block. All of my experiences with head studs and threaded holes that hit water jackets are if you do not seal the bottom threads on the stud (threads that are going into the block) with silicone the studs will weep coolant. I know you said you were going to seal put silicone on the top threads and bottom of the nuts but wouldn't that allow the cavity in the head that the headbolt goes through to fill with coolant?
Joe
Quick Reply: Weistec Stage 3 build w/ replacing head bolts thread.
