Just 2 screws hold on vorsteiner diffuser?
C63 AMG
Please if anyone with the vorsteiner diffuser can confirm that the only thing holding it on are the 2 screws on the two ends? I know it has the tabs but just want to be sure. Would hate to see it fly off at 150mph.. Did anyone add any other form of support? Thank you.
No problem, u definitely need the 2 bolts at the bottom or else ur diffuser will have a lot of stress from the wind blowing on it. Make sure u use washers & nuts on the bolts.
C63 AMG
Will be the first thing on my list in the morning! Knew I was doing something wrong felt dumb for asking but hey that's a big part of being apart of these forums:p thanks again bud!
Follow this DIY, it's very helpful. U can even see the bolts, washers & nuts I'm talking about. Good luck & post pics once u r done.
https://mbworld.org/forums/c63-amg-w...r-install.html
C63 AMG
Wow I looked and looked and looked for a DIY and didn't find one. Thank you so much this would have saved me a lot of time but it just helped me none te less. Nice work and thank you so much!
Do you know of a DIY for coilovers on our cars? Thanks again!
hey to be fair, for 2012 we dont have mounting points at the bottom other than clips and carbon fiber ones they have to make thinner than OEM plastics so the bottom clips dont fit as snug.
I will have to design my new super strong zip tie mounting system because I am done with losing diffusers...
I drilled two extra holes in the oem location under the diffuser and just made a little bracket to mount it to the oem location (shown in the DIY thread). Not sure of the 2012s have that mount point or not.
I find it strange that vorstiener doesn't have a pre drilled holes or a bracket included to mount their diffuser to all oem mount points. The only one I've seen that has it is the arkym rear diffuser
