C63 AMG (W204) 2008 - 2015
C63 Turbine like noise
Old 09-01-2014, 03:26 PM
  #51
Anatoli's Avatar
E500 estate
Thanks.
I will check on saturday and let you know if i find sth.
Old 09-01-2014, 05:48 PM
  #52
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
For info, in EPC the intake manifold is not broken down into subcomponents, i.e. the entire manifold, with tumbler etc., is all one number. The dealerships probably have to replace it all in one go.
On ECS Tuning the inlet manifold is available for 2679US$. There are 2 versions (1561410801 and 1561410901), the normal, and the Black Series (= same as 507?), both cost the same. So, if the dealership charges 3,500$ installed, it is not that bad.
Yes, an independent shop may be able to get you a couple hundred less, but not much.
Let me know, if I am missing something - always happy to learn!
Old 09-01-2014, 07:50 PM
  #53
Starky_'s Avatar
'10 C63 AMG
Originally Posted by jcfay
that whistle is NOT normal. I'm thinking vacuum leak. I get a slight, brief whistle on cold start about 10 seconds after start for 5 seconds or so; not sure if that is normal but I've never heard anything like what you've recorded.
Yup I have the same exact whistle on cold start ups on my 2010 PP.
Old 09-01-2014, 07:55 PM
  #54
jcfay's Avatar
2018 AMG E63s
Awesome! Was worried I might have a small vacuum leak myself after installing the Weistec air/oil separator, but since you've got it too it sounds like it's normal.
Old 09-12-2014, 08:25 AM
  #55
Anatoli's Avatar
E500 estate
I changed yesterday this part
But it was not broken - the part is ok.
After that we checked the screws from the intake manifold - 3 screws were not fixed.
After we fixed all 10 screws the noise was gone.
I hope that was the problem
Quick Reply: C63 Turbine like noise
