C63 AMG (W204) 2008 - 2015
Lowering Springs!!
Old 08-21-2013, 05:53 AM
Scottie46's Avatar
2013 C63 P31
Question Lowering Springs!!
So I've finally decided I want to lower the 63. I know that i don't want to go with coils, so I'm looking for the lowest spring that they make. So far I've only found H&R sports. Is there anything else?! I appreciate all help! Thanks!
Old 08-21-2013, 06:42 AM
olszowa12's Avatar
'08 C63 Estate
H&R is the way to go.
I don't know of any other manufacturer who makes springs for our cars.
Old 08-21-2013, 07:54 AM
AndresToys's Avatar
.C63 AMG Eurocharged,C350 Coupe(sold), Cl550 Coupe(sold), Slk350, BMW E92 m3, glk350 4matic
when you get them on the car, please post some pics. Much appreciated, im thinking if i should lower mine coming or just leave it as is.
Old 08-21-2013, 09:23 AM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
Plenty of pictures on H&R springs in the photo thread including my car, you should check it out.
Old 08-21-2013, 09:29 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
What about KW. People have been having issues with H&R. I had them on and sold them. Now looking into getting KW. Yes they are more expensive but worth it in the long run.
Old 08-21-2013, 09:31 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I didnt hear people having issues with H&R springs, only coilovers. KW are the best coilovers for our cars, but they are very pricey at 2k$+ !!
Old 08-21-2013, 09:40 AM
ZephyrAMG's Avatar
I can't remember which members it was but at least 2 have said that if they could do it over again they would chose KW...I am too lazy to search. Too much sound with H&R, they would give out, rubbing, and issues and contributed to power steering...
Old 08-21-2013, 01:40 PM
anthonymckay's Avatar
2013 C63 AMG
I had H&R springs on my first C63. This second time around I'm going with KW coilovers. I know the cost is substantially higher, but I just really didn't like how harsh the ride became with H&R springs.
Old 08-21-2013, 09:54 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
H&R springs are the inexpensive and quickest way of lowering our car. So far I'm happy with the result/ride. But for sure KW are top notch.
Old 08-22-2013, 12:50 AM
yazid's Avatar
C63 AMG P30 + OE Tuning
I had the P30 suspension on my C63, ride was high and stiff.
After extensive research, I opted for the H&R springs compared to the KW springs. Upon installation, I thought I'd be in trouble with rubbing with a full load and the tire wear as the camber has automatically became more aggressively negative on the rear end.
I use my car as a daily drive and til this day, I have had no problems with it, especially on Michelin's PS2.
Now here's the deal, with coilovers you have the liberty of manually changing the height of the car and thus will reduce the negative camber to save your tires. With the simple replacement of springs, you have a really nice lowered stance on the car, but may reduce your tirewear more than what you have right now.
I've learnt from other members that you may slightly increase the height on the rears with the replacing the current spring pads (14mm) to the 17mm.
So the choice is yours
Old 08-22-2013, 11:02 AM
4ramin's Avatar
2010 C63,1989 944 Turbo, 2018-GTR, GLC63S
+1 they are worth every penny
Old 08-22-2013, 12:19 PM
shades's Avatar
09 C63, 11 Cayenne S
I would stick with h&r just because they are so cheap. Again, I never heard of any problems with h&r so that could be just a isolated incident. Many people are running these springs and a very happy, me included. If you are doing track time, then I would definitely suggest KW. If it's your DD, h&r. My suspension actually got softer than my OEM springs believe it not.
Old 08-22-2013, 04:40 PM
jellis102.com's Avatar
KTM 200 xcw
I just removed my brand new H&R springs to install C/O's so they are for sale ($225 shipped) I have maybe 200 miles on the springs. LMK if you're interested and save almost $100
Old 08-22-2013, 10:21 PM
yazid's Avatar
that's a very good deal!
Old 08-28-2013, 01:56 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Labor to put on the H&R springs is the same as labor for H&R coil overs which work much better. Spend the extra money for the coil overs.
Old 08-28-2013, 02:41 AM
bhamg's Avatar
C63 AMG
This.
Old 08-28-2013, 03:09 AM
Scottie46's Avatar
2013 C63 P31
on the website for h&r it says it lowers .75 inches all around, but then at the bottom it says it can go down like 1.5 -2 inches. *****s is confused. whats the truth. heres the link. thanks
http://autoplicity.com/products/4776...FeZxQgod8wQArw
Old 08-28-2013, 03:40 AM
E55Tuner's Avatar
Is it a good idea to Only install the front springs to balance out the height since our cars are a bit lower in he rear? Not to mention the money saved on labor
Old 08-28-2013, 03:52 AM
guessqjj's Avatar
bmw
Old 08-28-2013, 12:09 PM
abcut973's Avatar
You can save money on labor by installing them yourself. I did it and it's not that hard. Just use proper tools and take your time.
But i would not recommend installing springs only in the front. Your car will probably be unbalanced and aesthetic wise it won't look good IMO.
Old 08-28-2013, 12:17 PM
dc5itr888's Avatar
Obsidian Black 2009 C63 w/ P30 Package
I believe I heard some members mention that most aftermarket springs are rated the same for the shocks, etc which means eventually your shocks will blow and you will have a really rough ride.
In the end I would also recommend just going with the full kw coilover system
Old 08-30-2013, 01:35 PM
Scottie46's Avatar
2013 C63 P31
So I guess now the question is which coil should I go for. I've been convinced. What's the best bang for my buck? Thanks gents
Old 08-30-2013, 02:22 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
The H&R coil overs are the best bang for the buck assuming this is primarily a street car. Also consider installing rear upper adjustable control arms (about $300 at ACG in San Diego) as lowering the car will induce more rear negative camber and there is no factory adjustment for it. (The rear tires wear out fast enough without additional help.) Also install front camber bolts (crash bolts). If it's worth doing it's worth doing right. Be aware you may experience some minor increase in noise in the rear end suspension as you are replacing rubber spring top mounts with alloy adjustable collars.
Old 08-30-2013, 07:46 PM
Roswell's Avatar
Why so many ppl complained about noisy/squeaky H&R coilovers? Bad batch or bad install?
Old 08-31-2013, 04:03 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
It's not a bad batch or a bad install. The factory uses rubber pads between the springs and perches. This absorbs naturally occurring spring noise. Coil- overs use a height adjustable alloy collar instead of the rubber pads in the rear (the rear of the C63 is not true coil-overs as the shock does not sit inside the coil). Hence some spring noise is transmitted into the cabin. Its a trade off for better handling. If you just use lowering spring, the pads are retained, but the shocks will wear out pretty fast.
Quick Reply: Lowering Springs!!
