C63 AMG (W204) 2008 - 2015
Post Akrapovic Evo Install
Old 02-09-2014, 02:39 AM
yazid's Avatar
C63 AMG P30 + OE Tuning
Hey guys, I was just wondering if anyone have had a similar issue as mine.
Eversince installing the Akrapovic Evo exhaust on in January, whenever I'm either on C/M/S and when I slam down the accelerator, there are times when the car goes straight to limp mode with the CEL lit up and the message says something like car is not driveable. So I just indicate to the hard shoulder, switch off the engine and restart and its up and running again.
This has happened like 3 times already. Temp is slightly higher than normal as it goes up to 106 degrees celsius (which I think should still be ok!). The past 12 months with just the Stage 1 OE tune and a RennTech CF airbox, I've never had a problem with this.
Appreciate if someone could enlighten me on this. I haven't even uploaded my Stage 2 OE Tune yet!
Old 02-09-2014, 05:57 AM
mr747's Avatar
c63
Do you have headers or just the rear section?.
Old 02-09-2014, 06:08 AM
yazid's Avatar
The Evo version is from the end of the headers to the tip. Its not the slip on at the rear section.
Old 02-09-2014, 06:11 AM
mr747's Avatar
c63
So u have standard headers with primary cats still in place??
Reason why I ask is when I put my headers on and left the stage one tune I was getting hesitation but no check light
Old 02-09-2014, 06:17 AM
yazid's Avatar
Yup standard headers are still on.. where are the primary cars located?
Hmm, I think I'll need to get it checked out at the garage.. wondering what's triggering the CEL. Could be one of the sensors.
Old 02-09-2014, 06:20 AM
mr747's Avatar
c63
Just after the headers there like ovel in shape
What is the cel light?? Do u have a obd reader?? What are the numbers??
Old 02-09-2014, 06:29 AM
yazid's Avatar
The Primary Cats are left on the end of the headers.
I understand the Check Engine Light is the yellow exclamation light that lights up on the left side of the Speedometer. Top of my head, the message on the speedo says something like "vehicle is not drivable". I'll take a picture of it when i get it again.
No I don't have an OBD reader. Do are cars use OBD or OBD2?
Old 02-09-2014, 06:39 AM
mr747's Avatar
c63
Take the car to Mercedes and get the codes checked
There are plenty of people here that can help you narrow your issue down and fix the problem
Report back once you know
Old 02-09-2014, 06:42 AM
yazid's Avatar
Cheers mate!
Yeah, currently chatting with the mechanic from the dealership who installed the exhaust on whatsapp now.
Will update once I receive further news.
Old 02-09-2014, 06:48 AM
mr747's Avatar
c63
Good luck yazid
Old 02-09-2014, 11:30 AM
Watchbeat's Avatar
2011 AMG SLS, K&N Air Filter, Cargraphic Exhaust, Klassen M51R Wheels
I have the same exhaust on mine for over a year now and no problem at all, it might be the tune.
Quick Reply: Post Akrapovic Evo Install
