235/35/19 - 275/30/19 Tire Setup on 19" Multispoke
No way Matt's car is at stock height, his car is slammed! Lol
U should be fine with 275/30/19 & no rubbing .. But u can't use spacers in the rear with that set-up!
http://www.ebay.com.au/itm/230858886...84.m1438.l2649
I know these arent genuine, but should be a nice fit on the C63.
Thinking of these....
I saw the photos cause I thought with the 10mm spacers at the front it’ll stick out wider than the rears, I’m running the same tyre size as you which is 235/35/19 front and 275/30/19 rear but just without the 10mm spacers and both front and rear width is equal I’m just curious with putting the spacers at the front if it will stick out a bit more than the rear or it’ll be equal width
Nick Gosal (10-29-2019)
