C63 AMG (W204) 2008 - 2015
Charcoal delete - wtf
Old 06-25-2014, 04:41 PM
kfriedenberger's Avatar
2009 C63 AMG
Am I an idiot or were these installed backwards???
Old 06-25-2014, 04:45 PM
Sidv22's Avatar
Audi A5 6MT, C63 AMG
They seem to be correctly installed.
Old 06-25-2014, 04:46 PM
Kriston's Avatar
C63 AMG
You are holding the filter housing up-side down.
Old 06-25-2014, 05:38 PM
Girard@ACGautomotive's Avatar
a car
If you're referring to them not being in the garbage can, then yes.
Old 06-25-2014, 05:49 PM
2009 C63 AMG
nice
Old 06-25-2014, 07:03 PM
DrLove's Avatar
2014 C63 Edition 507 / 2010 E550 Sedan / 2006 SLK 55 AMG
Take them out. I couldn't be happier after I deleted them.😃
Old 06-25-2014, 07:19 PM
2009 C63 AMG
Done. No butt dyno results yet or sound change, but it seems to idle at a lower rpm?
Old 06-25-2014, 10:19 PM
tfthach13's Avatar
'09 C63
I would keep the set just for smog purposes...just in case.
Old 06-25-2014, 11:22 PM
Conv_GSDriver's Avatar
'18 Audi A4
That's the next item on the list, AFTER i get the car smogged in cali and will change to the high flow right in front of the smog place and drive off.
Old 06-26-2014, 02:52 PM
Mort's Avatar
Hang on to them. You cannot buy them separate from the boxes.
Old 06-26-2014, 03:31 PM
Sincity's Avatar
That is odd.
Old 06-26-2014, 03:51 PM
2009 C63 AMG
I still think these were backwards. Air flows in the intake at the front of the engine bay, into the airbox bottom (where I found a leaf and caked on dust), then up through the main filter (orange rim on it), through the charcoal, then past the MAF sensors. If that's right, then these arrows are pointing the wrong direction (down in this case when the box is reinstalled). Where is my logic wrong?
Perfectly fine to confirm my idiot status, but I don't get it.
Old 06-26-2014, 03:57 PM
Ingenieur's Avatar
C63 AMG
It seems as if they were backwards
Old 06-26-2014, 06:30 PM
Mort's Avatar
I think you are correct when considering air entering the intake manifold when the engine is running. Maybe it has something to do with the intended purpose of the filters and that is to absorb gas fumes escaping in air exiting the engine when it is turned off. If this is the case then the flow is out of the engine and not into the engine. If this is the case then the filters are properly oriented. I don't know for sure if this is the case or the guy doing this boring job was having a bad day or in fact has a weird sense of humor.
Quick Reply: Charcoal delete - wtf
