Diff service due at 2K miles on '14 507 with LSD?
2014 C63 AMG 507
Yes...that is correct. There is a huge warning sticker on the inside of the windshield stating this when you buy the car. Maybe the dealer ripped it off when prepping the vehicle for you
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Yes. The factory LSD is intially filled with a "break-in" fluid that you need to change after the first 3K km, but not every 3K km thereafter.
Forum Search works great: Just changed Differential Fluid
If you have any questions about the procedure just send me a message
P.S. Here is a link to the Maintenance Manual for your car: 2014 Maintenance Manual - C Class
I called the dealer to get rear diff fluid and they told me to run the Castrol syntrax 75w-140.
According to my owners manual, this fluid is only required if you have the performance package with limited slip diff, which mine does not. Parts guy at the dealer said that they run the same fluid in all the AMG cars. Is this correct or should I stick with the Fuchs?
https://bevo.mercedes-benz.com/bevolisten/231.1_en.html
If you look up sheet 235.7 you will see the approved rear axle gear oils. Looks like Fuchs is one choice of 4 and Castrol Syntrax is not one of them.
https://bevo.mercedes-benz.com/bevolisten/235.7_en.html
Use the above information at your own risk.
