VFR difusser install HELP
C63 AMG '13 Coupe PP
Hi guys.
Did anyone install the diff. mentioned above.
I did found a good write about how to do it but that was a different brand.
The one I have is missing the 2 little lips in the middle of the diffuser where you would transfer the oem bracket.
The question is that did any of you put on an aftermarket diffuser and did not bother transferring the oem bracket thingy over to the new diffuser?
thanks
thanks
Very interested in the answer to this question - I have a VFR diffuser sitting on the shelf ready to be installed!
Here is the DIY thread the OP is referring to, I have it bookmarked.
https://mbworld.org/forums/c63-amg-w...r-install.html
Hi guys.
thanks
thanks
feel free to PM us if you have any other questions and we can give you some step by step instructions.
Just to clarify, your diffuser does not mount the same as the thread posted above because the facelift models do not have the brackets in the middle like on the pre facelift
Im in uk and my car is a 2013,so def facelift and it has the brackets
I haven't looked at a FL so I cannot say whether it's the same or not, but fwiw on my PFL, I just used a couple of long bolts in lieu of the brackets. There's a thread in here about it.
