C63 AMG (W204) 2008 - 2015
O2 Sensor Bosch part #17016
Old 03-16-2015, 10:19 AM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Have seen conflicting information through a forum search, and the Bosch website search turned up nothing for O2 sensors. Does anyone know for sure if this is the right part number for the upstream (pre-cats) sensor?
If so, there's a great deal on Amazon @ $95
Amazon.com: Bosch 17016 Oxygen Sensor, OE Type Fitment: Automotive Amazon.com: Bosch 17016 Oxygen Sensor, OE Type Fitment: Automotive
Old 03-16-2015, 01:19 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Yes. That's the correct part. I guess you got the p2626 code, huh?
Old 03-16-2015, 01:29 PM
BLKROKT's Avatar
Thanks for confirming man. More on it later in a separate post. Installed my MBH headers/mids/X over the weekend, and threw a CEL after a few rips up and down the street. Going out to check the codes now, but pretty positive the 20k mi O2 sensors died (I hope). For $95, they were worth ordering anyway.
Old 03-16-2015, 01:59 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
That is the correct part. I finally got around to installing mine this weekend. Much cheaper than the same part from MB (same part... different packaging)
Old 09-02-2015, 10:15 AM
Mr. Lin's Avatar
2008 C63
as far as fitment is concerned, this part from Bosch is plug n play, correct? there's a person on amazon who reviewed this specific part number and said it didn't fit, but failed to provide pertinent information regarding his vehicle...
Old 09-02-2015, 10:56 AM
mr747's Avatar
c63
I've been through 6 of these bad boys
pITA
Old 09-02-2015, 07:53 PM
WESLEY KAY's Avatar
2014 C63 AMG 507
Thanks op for writing this. Does anybody know the part number for the rear sensor??
Old 09-02-2015, 07:55 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
What are the risks of running the car with a bad o2 sensor?
Old 09-02-2015, 09:41 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
RearO2 Sensors are Bosch 16749.
Caution: I got this from another forum member and noted it for future use. I have not personally confirmed this (I think even if they were dead my tune would probably suppress any error message from the rear ones, so I am kind of hoping to never need one.)
Old 09-02-2015, 10:07 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
You run lean and melt piston heads...
Old 09-02-2015, 11:56 PM
w204nyc's Avatar
What if the o2 isn't burned out but there's a short circuit?
I had code P2629 open circuit pre cat
Old 09-03-2015, 06:34 AM
Wobble64's Avatar
Whenever the sensor is out, it cannot get used for automated Air:Fuel Ratio control and the engine switches to the programmed maps. If those are fine/conservative enough, nothing will happen, except the AFRs are not optimal (slight loss of power, maybe slight increase in fuel consumption). If the underlying maps are not right, e.g. when running headers without corresponding tune, then the engine could run dangerously lean.
Old 06-14-2017, 02:07 PM
Infiniti's Avatar
a unicorn tuned p30 e63
amazon is showing 17016 to be left upstream and 17019 to be the right. this correct? the right one is a bit more expensive.
Old 06-14-2017, 03:10 PM
Wobble64's Avatar
As far as I know the left and right are both identical and both are Bosch 17016
I am Jeff (06-14-2017)
Old 06-14-2017, 04:06 PM
Jasonoff's Avatar
2010 C63 AMG
What about NGK 24330?
Old 06-14-2017, 04:48 PM
chrisridebike8's Avatar
'10 C63
O'Rielly's is really good about honoring the 1 year warranty. I just told them they failed and they gave me new ones. No questions asked.
Old 06-14-2017, 05:00 PM
bhamg's Avatar
C63 AMG
I consider Bosch/NGK-NTK/Nippon Denso to be quality-equivalent choices. That said, Bosch does not deliver the expected service life in this application IMO. I've switched to Nippon Denso, would love to see others try NGK-NTK.
Old 06-14-2017, 05:28 PM
BLKROKT's Avatar
My Bosch sensors have been great for over 2yrs since replacing when I did the headers. Have about 20 track days and a hundred 1/4mi passes on them too. No durability issues here at all.
Old 06-14-2017, 06:34 PM
Jasonoff's Avatar
2010 C63 AMG
I haven't replaced mine yet on my 2010. I'm not burning any more/less fuel than normal so how can you really tell until they completely fail?
Old 06-15-2017, 12:13 AM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
Your check engine light will come on when it senses improper readings
Old 06-15-2017, 12:07 PM
Jasonoff's Avatar
2010 C63 AMG
That's exactly my point. An 02 sensor could be giving false readings as it degrades. ECU could adjust with false readings causing a rich/lean condition without detection.
Old 05-31-2019, 05:23 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
pITA
any idea why you've been through so many? think it is the tune? I've just put in my 2nd set in 4 years. I think its my tune. maybe their location on the headers. think its the tune though. will be purchasing HP Tuners at some point as this is the first vehicle i've gone through sensors so quickly, but also the first car i've purchased a canned tune.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 05-31-2019, 10:54 PM
kkkk's Avatar
W204 C63 Estate
It seems our part numbers are a little different here in Australia
The part I have is BOSCH 0 258 017 016. Is this the same?
Old 06-01-2019, 09:01 AM
PeterA90's Avatar
c63
Which headers do you have? Also, are you running e85 or race gas... particularly with lead
Old 06-02-2019, 07:27 PM
mr747's Avatar
c63
Race gas kills them switching between ms109 and 98RON destroys them
Quick Reply: O2 Sensor Bosch part #17016
