On my way home from the track. P2101 comes up
So I'm on my way home from the track and in the middle of the highway my car bogs down to 20kmh. I pull off and get a tow home. My friend plugs in his OBD2 sensor and the code P2101 comes up. "Mercedes-Benz - Throttle Actuator Control Motor Circuit Range/Performance". We reset the car and everything works fine. About 20mins later it happens again.
While on the track I did not push it too hard, it was in sport mode the entire time and left traction control off. What could be the possible cause and solution? Thank you!
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
A sticky throttle blade or a wiring issue (ECU to throttle body) would be my first guesses. It may have been triggered by the higher under-hood temps at the track, but it's generally not something that you would damage by tracking the car.
