Are the hood vents in my 507 installed correctly?
Gents,
I noticed today that one of the hood vents was about to unclip from the hood and after pushing it up it's back to normal when I took delivery of the car. However, I question the actual way it's currently installed:
Driver:
Passenger:
Overall:
See the gap between the hood and vent? Should it be sitting flush? I guess I can try unsnapping them and re-inserting but wanted to get your thoughts.
Thanks in advance!
Driver:
Passenger:
Overall:
Thanks in advance!
'13 C63 AMG P31
It seems that it just depends. I have seen it both ways, where it sits flush and where one side is slightly lower. Is there a way to adjust the clip at all?
More pics - https://mbworld.org/forums/c63-amg-w...d-vents-2.html
I'm thinking the ones that sit flush were purchased afterwards, and the slightly lower ones are from factory. Just a thought though.
Fixed!!!
Well I decided to tackle this tonight since they started dropping again.
Took them off the hood.
Basically there's a 3m double sided strip on each side that attach to the hood. Looks like it wasn't thick enough to affix to the hood. All I did was remove and install two strips on each side as I didn't have one roll of the thicker one and voila...I'm pleased.
Removal: remove the covers from under the hood and press on the sides from underneath while pushing up.
To reinstall them, just peel off the red adhesive cover and align vent on hood. Gently press down until you hear the clips click and should be fairly flushed with the hood (maybe 1-2mm deeper) and just press on the sides from underneath.
Reinstall covers from under hood.
See pics.
Sagging and dropped.
Old adhesive strip
New...
Cleaned area folding down on hood where adhesive will affix.
Other side
Boom!
Boom!
Boom!!!
See pics.
Old adhesive strip
New...
Other side
Boom!
Boom!
Boom!!!
The following 2 users liked this post by latinskllz:
james_duro (08-16-2018),
myNAMESterry (09-03-2020)
Mine drop out of the slot every time the car wash guy washes my car. I've reinstalled them 3 times already. Maybe some new tape is in order.
C63 507 AMG DA Car #19
Good write-up.
One of my hood vents is sagging too.
Your step-by-step is in order.
Designo Magno Matte is super easy to maintain. It's almost like a non-stick pan.... if you keep it conditioned dirt just slides off.
Looks like 3M trim tape with the red peel off strip in post #8. The tape used is also a bit wider than the OEM tape from the look of it. Not sure if that will help or not. Depends on the area the tape will bond to. No report to date saying how the 3M tape has stood up to the high engine temps in our C63s.
I saw on ebay replica (for a clean installation)
made as an alternative to
And here is the terrible quality makes Duraflex (Duraflex® 112445)
for an unreasonable price
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
latinskllz (03-02-2017)
Wanted to add another tape alternative for those who are in a similar boat, or who will be seeing very high temperatures in general, and at the track:
3M™ VHB™ Tape GPH-160GF appears has the highest temp rating (Peak 450F, sustained 300F) and performance characteristics of their VHB series of tapes, in addition to it being 1.6mm thick - see attached PDF for data sheet.
Also attached the data sheet for the 3M 03614 tape that OP had used.
