C63 AMG (W204) 2008 - 2015
leaking coolant
Old 10-20-2015, 12:02 AM
mikeyyyallday's Avatar
2011 MB C63 AMG. 2014 MUSTANG COVERTIBLE V6. 2010 MUSTANG CONVERTIBLE V6.
leaking coolant
my coolant level warning turned on. so i got coolant and filled it. and now the warning came back up. so i checked it and it was hella low, looked under my car and its dripping coolant...will this be an expensive fix? whats most likely the problem? my warranty just ran out in august. FML
Old 10-20-2015, 12:35 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Could be a cracked reservoir, a bad clamp, a popped hose, cracked rad ... Do you see any spray marks?
Old 10-20-2015, 12:37 AM
computertom's Avatar
2017 911, 2012 C63
Yes, if there is coolant underneath the car, it's likely something not too crazy. If theirs no sign of where the coolant is actually going (i.e.: into the combustion chamber), things could get really ugly. The fact that you can see the coolant is a really good sign. Still, you should get it looked at asap and not drive it.
Old 10-20-2015, 12:39 AM
Merc63's Avatar
C63 AMG
You want us to advise on repairs based on a pool of coolant under the car... Owns an amg, asks if it could be expensive lol.
Old 10-20-2015, 01:46 AM
yeah I'm bringing it in tomorrow, doesn't look like any spray. jus dripping under my car. i will have to fill the coolant before i even take it in
Old 10-20-2015, 07:57 AM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Dude, just get the car towed to be safe. Be smart.
Old 10-20-2015, 11:07 AM
Dumb question, but are you sure it's coolant? Obviously the system is pressurized, so there should be some kind of spray pattern. Unless it's leaking after filling and you haven't started the car.
Old 10-20-2015, 03:25 PM
yeah its just dripping as i fill. its at the shop now, so we'll see
Old 10-20-2015, 04:43 PM
Ok. Let me know what it ends up being. I'm curious.
Old 10-20-2015, 08:17 PM
AMGPower88's Avatar
C63 AMG
Low coolant= headbolt issue ..?
Old 10-20-2015, 09:35 PM
downshiftM156's Avatar
2009 C63
How many miles are on your car?
Old 10-22-2015, 05:44 AM
red60R's Avatar
2017 C63S
that's what my immediate thought was after seeing so many of these threads in the past
Old 10-22-2015, 08:07 AM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
Low coolant without any sign of external leaks may = headbolt issue.
Not the case here...
Old 10-22-2015, 10:31 AM
jpsingh's Avatar
2011 C63 PP
I had a similar issue 4 months ago. 2011 C63 PP. Dealer found leaking coolant after they did a service.
They ended up fixing this :
1) They found that the Front Timing Cover was problematic and had to be replaced.
Part : 156 010 24 33
2) They found another leak from the radiator as well while changing the Front Timing Cover.
Part : 204-500-31-03
It was fix under warranty so i'm not sure how much it would have cost me but I wouldn't be surprise if it was around 7000$ - 8000$ CAD (dealer price of course)
They had to take out the engine from the car to change the Front timing cover.
As other mentioned, if the coolant leak is visible, I don't think it's the headbolt.
Old 10-22-2015, 03:05 PM
yeah i had the head bolt issue already, and that was fixed under warranty. now I'm out of warranty and if this costs 7k-8k I'm fkeddddd lol
Old 10-22-2015, 03:07 PM
I'm scared now. the car will be done today or tomorrow, so ill keep you guys updated on the damage to my bank
Old 10-22-2015, 03:29 PM
jpsingh's Avatar
2011 C63 PP
you had headbolt issues on a 2011 or changed them by precaution?
That's interesting, I thought most of 2011 had the updated headbolt. Do you happen to know what engine number you had!?
Don't panic just yet... you might have totally unrelated issues. If they are supposed to finish by tomorrow, why not just call them and ask them what they are fixing?
Old 10-22-2015, 03:31 PM
my head bolt failed, and then was replaced by warranty. i believe early production 2011 models had the issues. some 2011's are safe. i called the shop yesterday, but couldn't hear him to well on the phone lol. all i heard was it'll be done today or tomorrow
Old 10-22-2015, 03:43 PM
jpsingh's Avatar
2011 C63 PP
Ho I see, so you were in the early 2011. mine is actually like 2000 engine number after they are supposed to have make the switch. since day one, I've always kind of been worried about what if the engine number where the switch happened isn't super exact and I do have the old one.
I had a chance to verify it when they took the engine out to fix the timing cover but blew it by calling them too late and they had already put the engine back in the car.
ho well.
Good luck with your repair
keep in mind I've mention what I think it would have cost me in my area. Everything cost more here in Canada so a 7000$ repair here is probably a 5000$ repair in US.
Old 10-23-2015, 05:35 AM
2009 C63
If you've already had the head bolt go out & replaced then I would guess it might not be the same expensive issue, so I would take comfort in knowing that! What mileage did your head bolt fail at?
Old 10-23-2015, 06:48 PM
8o8is's Avatar
'10 C63
Sub'd for updates. Hopefully something simple since it's an external leak.
Old 10-23-2015, 09:07 PM
the culprit was a bad radiator....my car only has 27,xxx miles...cost $1043 to fix at an independent mercedes shop
Old 10-23-2015, 09:56 PM
Jasonoff's Avatar
2010 C63 AMG
Was it punctured? How does a 4y/o rad go bad?
Old 10-23-2015, 10:05 PM
I'm confused myself.
Old 10-24-2015, 01:52 AM
In any event, glad it wasn't a too too serious matter.
Quick Reply: leaking coolant
