E63 wheels on a C63
Mercedes C63 AMG
The rear will be fine taking for granted the spokes clears the brakes.
The front will be very aggressive so I would recommend 235/35/19.
Mercedes C63 AMG
I already have 245/35 19 tyres will these not work? I don't want a silly stretch on them you see.. Will my original wheel bolts be ok?
I'm running 19x9 +40 with 245/35/19 & it's super tight. But I'm lowered.
IF u are at stock height, u will be fine although u might get rubbing on big bumps.
As for the oem lugs, check if E class cars use the same M14x1.5x27mm.
Mercedes C63 AMG
I do plan on lowering it so do you think I would be fine with 235 35 on H&R's?
Mercedes C63 AMG
Also sorry for another question... I have purchased some Yokohama advant sport tyres and it says on the inside of the tyres, warning do not mount on a 19.5 inch rim. Any reason for this?
Because...they are for a 19 inch rim? Same reason you don't put a tire meant for an 18 inch wheel on a 19 inch wheel.
Actually u should buy my multispokes spokes, I think they suit the C63 better.
And yes don't mount those 19's tires on 19.5's rims.. A disaster waiting to happened. Lol
Mercedes C63 AMG
Mercedes C63 AMG
235/35/19 will be safe for 19x9 +37 & H&R springs. Good choice on the Yokos AVS sport, I run them on my multispokes & they are great tires.
Thanks again
Can't wait to see the installed pics, the front should be flush.. You can even go 275 in the rear with +52 offset.
I'm running E63 W212 wheels in 18" but with same wheel width and offset. I'm able to fit 255 front and 275 rear.
Edit: I'm on stock suspension.
If you're lowered, there's no way you can fit 255s. If you're stock height, then yes, you'll probably be OK.
Like Roswell said, 235/35/19 and 265/30/19 would be my suggestion. You could size up to 275/30/19 too, but then your aspect ratios will be slightly off, that's not a huge deal though.
The new finish looks great! The red ring is also a nice addition. Installed pics yet?
Mercedes C63 AMG
Either a bad wheel balancing or either ur wheels are not hubcentric (66.6 Centerbore) so u need hubrings.
Wheel balancing is the first thing I'd check. I'd ask them to check for wheel straightness while they're checking balance, as a bent wheel can cause the same sort of vibration.
I'm pretty sure that all AMG wheels (except maybe the G_wagon) have the same centerbore.
http://www.wheelsupport.com/mercedes-benz-bolt-pattern/
As long as these are real OEM wheels (not replicas), they should center perfectly.
The front is pretty aggressive but looks good. The rear I had to raise the ride height up in the back from being lowered a little on the coilovers
Roadtalontsi - Nice pic. Are those E63 wheels?
. . . and how did you get that Battleship all the way up to DFW?
