Larger diameter tire in rear
Anyone successfully run a larger diameter tire in the rear exceeding the 3% tolerance for the esp and tcs?
I have a 235/35/19 in front and want to to install a 265/35/19 in the rear. It is 3.1% larger in diameter compared to the front, will I run into any issues?
No, you will not have any issues with ESC ABS or anything similar. I am running 255/40/18 winter tires, 3.9% bigger than stock and 2.5% larger than the front. Normally the fronts are 1.8% larger than the rears, so the change vs the stock setup is 2.4 + 1.8 = 4.3%. Still no issue.
Last edited by Wobble64; 05-23-2016 at 08:28 PM. Reason: added info and corrected typo in rim diameter
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
No he'll be fine. I've run up to 3% difference with drag radials no problem.
thesaintusa (05-22-2016)
Most people want the front and rear tire size to look about the same from the side. In addition to aesthetics, it also keeps the car level.
If you are trying to achieve the appearance of the same amount of tire height on each wheel, using the same profile for both won't work. The profile number is a percent, not a measurement. On a 35 profile tire, the height is 35% of the width. If you get a wider rear tire and keep same the profile, your rear tire will be taller.
On your 235/35/19 front, the tire height is 35% of 235mm = 82.25mm
People who want the tires to look the same from the side will match that front tire with a 275/30 rear because the tire height is .30x275=82.5mm. If you're lowered and a 275 won't fit, 265/30 is next best option at 79.5mm.
If you instead use a 265/35/19 in the rear, tire height is .35x265=92.75mm.
Yes I am aware of this info. Thank you. Max I can go is 265 but that's on a 10.5 wheel. Reason why I want to go a profile size up, to not put too much stress in the stretch. The stretch itself doesn't help the appearance either. This is all temporary anyways till my body shop is finished with a few projects. Once he widens the rear fenders I'll be able to fit hopefully a 285.
it's good at 265
i have a forgstar wheel 52 offset 19 x 10 and i install 265 /30/19 and it fit just right
watchout for your weight ratio at 93 it's important don't choose a 87 rating the weight ratio is too low for the C63
Stagger fit cars (oem or aftermarket upgraded) pretty much never use the same profile front and rear.
