Radiator Support Piece Part #?
Broke this little plastic piece that sits on top of the radiator support. I'ts rectangular and plastic.
I've search all the part's diagrams and can't find this piece. Anyone have an idea or does it come with the entire radiator support it sits on?
Received 2,845 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That's not the little t-shaped piece that bolts up to the front grille, is it? Because I removed it for about a year before I put it back on recently only to help support my Gruppe M-type cold air intake. Totally 100% unnecessary.
This?
This?
GHAZAN (06-26-2016)
Yea yours looks a little different but that's the one. I have a 2009, they probably changed it a bit. More of an OCD repair than necessary since I broke it. I figured it couldn't cost that much....unless I have to buy the whole radiator support than I'll pass.
There's a number stamped into the back of it if you still happen to have the broken piece. All it does is connect to the top of the grille, it doesn't support anything else or serve any other purpose, and the grille doesn't need it to function.
Post or PM your VIN and I'll get you the part number.
I sent you a PM Valvestud, thanks
