C63 AMG (W204) 2008 - 2015
what are your thoughts on running 285s in rear with stock front fitment?
Old 09-10-2016, 04:08 PM
skratch77's Avatar
2005 E55
I'm not sure why mb put 255s on our cars but I'm thinking of just st going max wide I can go on the rears and maybe use a spacer combo for the front to compensate?
only reason i want to keep front stock size is I can't find a tire that has a 25.2 in rolling diameter like the stock rears and found a 285/30/18 that has the same rolling diameter as the stock setup.
say a 12-15mm spacer in front and an 8-10mm out back?
Old 09-10-2016, 07:18 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Your going to run a 285 on the stock 9 inch rear?? Yea going to feel squirmy. And then a 10mm spacer to take the stock rear et to 44 with the 285 yea I'm thinking def no. At least not without rubbing
Old 09-10-2016, 08:59 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I ran 285/35-18 Nitto drag radials on stock rims. No spacers. No rubbing. Was stock suspension height then.
Old 09-10-2016, 10:06 PM
skratch77's Avatar
2005 E55
maybe go with a 275 rear then.
Old 09-10-2016, 10:47 PM
jay rick's Avatar
C63 2009
285 on 9" is a bit too wide. Running 285 is like running 15 mm spacers for the tires. If you spacers it might rub.
Old 09-11-2016, 07:08 AM
AMGonFire's Avatar
now correct me if I'm wrong but don't those run skinny they are not comparable to other tires in 285.
Old 09-11-2016, 07:42 AM
BLKROKT's Avatar
I don't know, you can look up the specs at TireRack on section width and tread width and compare to other tires.
Old 09-11-2016, 11:32 AM
skratch77's Avatar
2005 E55
yes u can under specs and u can play with all the different diameters to get the ratio you want.
used it alot for my e55 to get a really tall tire to help put the power down and get it just right in the top of 3rd gear just hitting the end of the 1/4 mile to not shift.
Old 09-11-2016, 12:35 PM
Overspooled's Avatar
Slow Vehicle
Im running 275's on stock wheels and it is just right. I do feel it is a little more squirmy than 255's though. 265 must be a perfect size for a 9 inch wheel but I personally like a chunkier look.
Old 09-11-2016, 01:08 PM
BLKROKT's Avatar
Right. I know, thanks. That's what I said. I use it all the time to figure out which tires can fit. I was saying that I don't know the answer to your question, and to look it up versus other tires. I think it's a 'normal width' 285 but it depends what you're comparing to, which I have no idea.
Just saying that they fit for me. In answer to the original question.
Old 09-11-2016, 08:08 PM
jptaylor's Avatar
2009 C63 P30, 2008 Grand Cherokee SRT8(RIP)
I ran 285 M/T Street Comp rears on stock 18s for about a year and a half...no spacers...no rub...no issues And I didn't feel that they were any squirmier than stock...
Old 09-11-2016, 09:35 PM
skratch77's Avatar
2005 E55
what are you running for fronts?
Old 09-12-2016, 10:13 AM
akmatic63's Avatar
10 C63, 06 S65, 14 ML350, 95 S500
275 MPSS on stock 18s with 2" drop works good no rubbing or anything. Barely a 5mm gap between tire and fender though.
Old 09-12-2016, 10:43 AM
skratch77's Avatar
2005 E55
looks good! what size did you run in the front and did you need and spacers?
Old 09-12-2016, 02:15 PM
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
I run 285/30 rears and I love them. No issues at all.
Old 09-12-2016, 07:18 PM
skratch77's Avatar
2005 E55
stock wheels? what front size are you running? that is the size rear wheel I want to run
Old 09-12-2016, 07:24 PM
C SEXY 3's Avatar
Yes stock wheels, I will check once I get home from office in about 30 minutes.
Old 09-13-2016, 12:23 AM
604 C63's Avatar
2012 E550 Cabrio
I can vouch for this. I had 18s on my 09. Same rims. When I ran factory rubber size I had a 12mm spacer up front, and a 10mm in the back.
Then, I took the spacers off, moved the 255s to the front and put 275s on the rear. Looked like a hot damn, gripped up much better too. Even though I had LSD when pulling out of one particular corner at my local track I always had to lay off a bit or I was just shredding. With the 275s it hooked up much better.
Quick Reply: what are your thoughts on running 285s in rear with stock front fitment?
