nearly :(
nearly :(
The following 2 users liked this post by mr747:
BLKROKT (09-18-2016),
Celicasaur (09-20-2016)
^^^ thats on pump 67mm
this is on 60mm with ms109
Received 2,845 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
650whp sweeeeeeet
Engine's moving around a lot. Have you considered strapping it down? Used to use motorcycle ratcheting tie-downs for that.
i never thought about it to be honest
the power difference is night and day
but i custom tuned the 60mm pulley tune
THe weistec bench tune is very safe and you will have no issues running the 60mm pulley on there base tune
NO i have 2 ecus both custom tuned now
i could of went more on the 60mm pulley tune but i wanted it safe i had another 3 degress timing to go
my fuel pumps are also maxed now so i didnt want to risk damages
its plenty now
Its a whole different animal its scary 50whp gain from the change of pulleys
but un-tuned its will be more like 20whp on bench tune
its plenty now
yes stock except for head studs
put it on bud its safe just run straight ms109
The bench tune is safe only 15 degrees timing mines up to 18 degrees now
you will be safe
you will be safe
I have to double check mate leave it with me
mr747 (09-21-2016)
mr747 (09-21-2016)
