Unusual wearing of passenger front tire
Hi All,
I recently purchased a 2009 C63 AMG about 3 months ago and learning a lot about the car.
Recently removed the front 2 tires and noticed that only the passenger side tire has chunks missing from the inside of the tire.
Is this an alignment issue or bushing issue? Thoughts?
Typical wear pattern caused by a combination of deault negative camber and intoeing setup from the factory. However, it should affect both tires on the same axle. Well at least wires haven't poked through yet. Always keep an eye on all tires' inner edges from time to time for AMG vehicles.
Or would i need a after market camber kit?
I'm betting you will need the aftermarket camber kit to fix this, but I'm not positive. It's surprising that such a nice car doesn't have a camber adjustment!
You will need new Camber bolts any time you get it aligned my tech told me.
These car are designed to run from -1.39 to -2.11 degrees of camber from the print out off my dealer's new equipment and 0.10 to 0.27 degrees of Toe.
I would start there as any mechanical deficiencies will be spotted when they prep it for alignment by replacing the Camber bolts.
It cost me $350 CDN to get it done including the bolts and one other part but they also corrected the rear thrust angle too.
Well worth it in my view.
Ok! So I bought my car at the end of September and it went in for a full check up and service including 4 wheel alignment. This looks to me to be possible excess cambre either as a result of worn suspension components, accident damage or just plain neglect.
Camber
Left Front -1.85. Right Front -1.96
Toe
As to your question re wear. Too soon to tell as I put new winter tires and wheels on right after they did the alignment.
I cannot tell you anything about the summer tires as it is clear that the previous owner ran the tires softer than spec. There is significantly more wear on the shoulders of both front tires than in the centres. There is 8 mm of tread on both in the centre. The LF inside has 2 mm, the outside 2 mm. The RF has 4 mm on the outside and 3 in the inside so it is hard to say if the wear is alignment caused or low pressure. I expect now that I know this I might run 1-2 psi harder than suggested come spring and see if the wear evens out.
0.13 Left 0.16 right
Caster 11.11 Left 10.65 right
Rear Camber Spec is -1.48 t0 -2.48
Left -2.29 right -2.36 ( I don't know if there is spec for non- staggered set up)
Rear Toe Spec 0.01 to 0.25
Left 0.08 Right 0.11
Total Toe Spec rear 0.14 to 0.38
Total Toe 0.19
Thrust Angled spec -0.12 to 0.12
Thrust angle -0.02
Before alignment right front camber was out at -2.29.
The rear thrust angle was close the bottom spec of - 0.12 at -0.14
'99 and '05 E55 AMG
The tire looks like it has toe out rather than toe in; you can tell by the way the rubber is peeled away from the inside edge. Could be just an adjustment to the tie rod end but could possibly be a bad bushing, bad ball joint, or combination of the above. How many miles on your car? If you're over 85,000 miles, time to start looking at the suspension bits wearing out. If less than, I'd go with a toe adjustment.
Let's see here.
Camber
Toe
Total Toe 0.19
Thrust angle -0.02
Camber
Toe
Total Toe 0.19
Thrust angle -0.02
Thank you so much. You are running plenty of front negative camber, I'll check to see where I am.
C63 AMG, P30
It could be excess Camber as well so he really needs to get this car checked out and aligned.
I have had the same issue of wearing out the inside of the front tires to the cord. I just checked my camber and I have 1.8 degrees negative on the right front and 1.4 degrees negative on the left front.
The point I have made is that he needs to get this car in, have the front end fully inspected for wear on the mechanicals, bushings, tie rod ends etc. and then put on a quality alignment machine and sorted out. Then and only then will he know. We are all just guessing. The best we have to offer at this point is what he already knows. Something is not right.
C63 AMG, P30
We don't know that it is toe or camber. Excess negative camber (by spec these cars run negative camber) will put pressure on the inside edge of the tire. It could of course be a case of excess camber AND incorrect toe as you suggest.
For the record, the image of the OP's tires is NOT camber wear. That's for dang sure. This is camber wear:
You could be right. I get what you are saying so let's agree there is no contest of opinions here and we do agree on the key point.
He has to get the car checked and aligned.
C63 AMG, P30
In the extreme eh? This is not normal camber wear on any street car. Look at the exposure of the cords right over into the side wall. This surely has to have come off some thing driven very hard with purposely set high negative camber. We see this all the time on NASCAR when right fronts blow from excess negative camber,
That being said, you see how the camber wear is smoothed over half of the tire? That's what I generally see when people refer to wear as camber wear. The reason I dismissed camber wear was the cupping/feathering right on the edge as the wear isn't really smoothed at all.
Yes, we're both agreeing here though. He definitely needs to hit the alignment rack and get a read out. If all of his specs are within factory spec or close too, at that point, it'd be best to start looking at other suspension components.
When i purchased the vehicle a couple of months ago and got a PPI from the Mercedes dealership they did not note any issues with the bushings but i'll have them check it again when they get it on up on a rack.
From what I have read so far that without a kit, toe can be changed but there is nothing you can do with camber. With camber kit outs there, you can probably change the camber. I wouldn't mess with changing the toe, though. It will really change the intended driving dynamic and feel.
