CL-Class (W215) 2000-2006: CL 500, CL 600
I can't find the rear fuse box - anyone?
Old 03-01-2008, 10:11 PM
jcarlosfox's Avatar
2002 CL500
In looking through the WIS disk, I see a reference to fuse boxes in the engine bay, one behind the passenger seat on the floor, and a "rear fuse box".
I want to access my "rear fuse box" because that is where fuse #70 that controls the Tire Pressure Control system is located on my 2002 CL500.
A call to the dealer led someone to tell me it was behind the rear seat - but no help in getting access. There does not appear to be a fuse box near the battery, and I pulled the trim around the CD Player, and there was no fuse box in that area - while I was there I made sure my Argus Bluetooth Phone system was plugged in (GREAT ADD ON - the BEST buy I've made, even at $800 bucks.)
So....does anyone know where the mysterious "rear fuse box" may be located?
Thanks,
JC
2002 CL500
Old 03-02-2008, 05:38 AM
beacham's Avatar
cl500 w215
try under the rear seat, had mine out and there's some under there
Old 03-02-2008, 08:40 AM
carson357's Avatar
2005 C-230 Sport Sedan
215 chassis read fuse box
it is under the back seat, but you gain acess through the light area by floor, see picture below, let me know if you need to know any other component locations. i am in san diego also, i am mercedes tech, let me know if i can ever assist you.
Attached Thumbnails I can't find the rear fuse box - anyone?-rear-fuse-box-215.jpg
Old 03-03-2008, 10:03 PM
jcarlosfox's Avatar
2002 CL500
THANKS CARSON!! Well, I knew about the fuse box behind the passenger seat - but the WIS disk referred to a REAR ONE, in addition to the one you reference - HOWEVER, you are absolutely CORRECT -it is ONE AND THE SAME!
THANKS!!
As I suspected, I pulled fuse #70 and was able to disable the Tire Pressure Control Module. Of course, the dash warning I had "REACTIVATE TIRE PRESSURE CONTROL" was replaced by "DISPLAY DEFECTIVE, VISIT WORKSHOP" - so, I still have not killed the Tire Pressure Control System, but at least I UNDERSTAND what's going on now.
Thanks again Carson.
Old 06-01-2009, 11:18 AM
svbsvb's Avatar
cl500
fuse diagram
Thanks for your answer.
For instance have you any fuse diagram? It's almost impossible to find and I have a big problem with my CL500 2001:
it's impossible to open the trunk and the oil cap...(but possible to close and open doors even if the little door button doesn't move and the door don't close automatically when you put it close to its closed position
thanks+++++
Old 04-29-2013, 09:01 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
yeah i'm actually looking to locate fuse 87 thats related to engine fan. 2005 model says its just in the engine wall but i cant find it on my 02 w215
Old 10-09-2014, 01:22 AM
Drmichael1950's Avatar
CL-600
Fuse Locations
There are four fuse boxed in the CL600. Two are in the engine compartment, one on each side, close to the windshield, near and almost under the left and right hood hinges.
There is one inside on the passanger side of the front dashboard. The panel that you have to remove (gently) to get at the fuses, is visible only when the passenger door is open. It has dashboard, alarm, instrument cluster, cig lighter etc. Merc calls this the front cockpit fuse box.
There is a fuse box in the back under the rear passenger side seat. But when you pull out the bottom of the seat, you will not see it. It is under the seat, but it is accessible from the front of the bottom of the panel under the seet. Don't pull the seat pad out, look under the front lip of it.
Email me if you need to know the layouts, I have a little chart.
Old 10-09-2014, 10:20 AM
ctravis595's Avatar
They actually vary by year so your fuse chart may only apply to a certain year as a sidenote
Old 12-05-2023, 09:07 PM
Mr.Jackson's Avatar
2003 cl500
Passenger side not getting power
since u are a tech my passenger side has no power I can't roll down my window or move the seat. I checked the wires in the door henge and no breaks and I have a new control module too
Quick Reply: I can't find the rear fuse box - anyone?
