W215 Front UCA's Ball Joint & LCA's Ball Joint
Hi guys,
Can anyone tell me if the W215 upper control arm's ball joint is the same part as the lower control arm/wheel hub's ball joint? They look like the same part to me. Please let me know. Thank you.
On a second thought, the ball joint on the uca isn't a through-mounted part so even if it's the same part, it would be very difficult to remove so never mind. Thanks
