CL600 Questions
03 CL600
So I have my car back and let me tell you guys. The plugs were horrible and they weren't the originals. They were some after market type that weren't good. So iReplaced all 24 of the plugs & boots, and guess what. NO MORE MISFIRES !! iGot the fuel filters replaced too while it was in the shop. But the thing is it doesn't feel like it accelerates as fast as it use to. Idk if its just me tho.
03 CL600
So I've been test driving all day and it feels the car has no power. Like the turbos just don't work anymore or something. Fix one problem and an even worse problem has occurred it seems. The acceleration at 2-3k RPMs is no different then when iFloor it to 5-6k RPMs.
Im going to call them again tomorrow to try to figure out something yet again, this is getting frustrating.
03 CL600
Took it back and a hose was disconnect. They used a clamp to keep it connected so it won't come a loose. Put it on I-95 and it took off. My baby is finally %100. Its a good feeling lol
Actually, I think I found both of our (past) problems. The boost pressure sensor right in the middle of everything. Super easy to break plastic tip.
I removed the broken plastic from the tube and forced the tube over the broken tip and put a small bit silicone adhesive. Drives like new now.
