CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
LSD on CL55 and CL65??
Rating: Thread Rating: 3 votes, 3.67 average.
Old 04-03-2011, 05:07 PM
KLR CLS's Avatar
CLS63 PP
I am 99.9 % certain that all AMG's use the same Mettinger HAG M215 Diff. The Quaif and wavetrac units should both work. Does anybody have a picture of the Diff on a CL65?
Old 04-03-2011, 07:05 PM
RaceHorse's Avatar
CL65
Originally Posted by Oxygen
My friend in Florida just installed this Quaife QDF9V LSD in a CL65 AMG...
Not that I don't believe you, with all the research and contributions that you have posted, but its hard to think that this LSD fits the CL65 considering that everything is so different on the 65 cars from the others. Also since this "QDF9V" fits so many cars (see link below). It does mention 215 chassis, but again I thought everything was beefed up on the 65's.
http://www.ahwooga.com/detail.asp?id=164485
Did your friend have to modify the stock housing? Could you elaborate on what was necessary for the install and/or if it was a direct replacement. Also is it rated for the torque of a stock 65 more importantly, a modified one?
Thanks,
~Rich
Old 04-03-2011, 09:12 PM
RaceHorse's Avatar
CL65
I just searched a little more and found 2 more sites listing the Quaife LSD for the CL65. From what it sounds like, its just a direct replacement. This could be a good thing.
http://www.phantasmusa.com/quaifeqdf9v.html
http://www.jdmhub.com/index.php?rout...duct_id=236730
Old 04-03-2011, 10:26 PM
KLR CLS's Avatar
CLS63 PP
If someone has a picture of a CL65 diff I can tell you right away...
Old 04-04-2011, 03:25 PM
france2112's Avatar
2015 Mercedes-Benz CLS63 AMG S
Guys, I am 1000% sure it does not fit. My car right now has that exact Quaife differential sitting on a table next to my car. My open differential is out, and my tech, who is a master Mercedes tech, assured me it does not fit. Plus, we called the North American distributor and they confirmed it will not fit. Whoever says they did it is either lying or completely modified their car.
Old 04-04-2011, 03:27 PM
france2112's Avatar
By the way, I called Kleemann and they can modify the existing open differential to a 60% LSD for about $1,000.00. Sending mine out today.
Old 04-04-2011, 03:30 PM
  #32
france2112's Avatar
I found these sites also, which is why I bought the Quiafe and tried to have it installed. That unit fits the 55's and 63's but not the 65's.
Old 04-04-2011, 04:05 PM
  #33
waxking1's Avatar
CL65
I like this idea. Please let us know how this turns out.
Old 04-04-2011, 04:21 PM
  #34
Stephen04E55's Avatar
'09 CLK550, '21 Camaro ZL1 1LE, '06 C55 AMG, '20 AMG GT53
The Kleemann unit works great and you will be happy with it. The Quaife one does not fit as stated even though the website may say otherwise. The 55/63 series cars have a different diameter ring gear. I have a broken middle section in the garage and the V-12 car ring gear is nearly 9 inches. I wish the pinion was as strong as the ring.
Old 04-04-2011, 06:36 PM
  #35
RaceHorse's Avatar
CL65
What a teaser, you must be the friend in Florida. (referring to Oxygen's post). I guess as always you can't believe everything you see on the internet, even if you want to. Seeing multiple companies list made me think it was true. Thanks for the big heads up france2112 it did seem too good to be true. It looks like Kleeman then which may not be a bad thing, based on Stephen04E55's success with it. Good luck.
~Rich
Old 04-05-2011, 12:24 AM
  #36
france2112's Avatar
Thanks again for the for your input about the Kleemann LSD . Really appreciate it. This is why our forum and our brotherhood is awesome!!
Old 04-05-2011, 12:28 AM
  #37
france2112's Avatar
~Rich
No problem my friend. I will let you and everyone know how it works. FYI, I just installed the Speedriven top mounted intercoolers, scorpion air intake, and the ECU / TCU upgrade. This is why I wanted to have a LSD to help harness all my new power. I have yet to drive my car because after my tech installed the upgrades I had him order the Quaife LSD and take my open differential out. He test drove it before he took out the differential and said it is an absolute friggin monster!! Can't wait till I get it back!!!!
Old 04-05-2011, 05:42 PM
  #38
RaceHorse's Avatar
CL65
That is really cool to hear!!! I couldn't agree with your thinking any more. It would be a sin to have all that power and not get the shove off the line that the car is truly capable of. The other thing is sharing the 1,000 ft./lbs of torque to both wheels gives your axle a fighting chance. I think a few of them snapped with that set up and drag radials.
Old 04-07-2011, 03:03 PM
  #39
Former Vendor of MBWorld
Cory @ Kleemann's Avatar
W215 and W220 cars be it a V8 or V12 have the same differential, and the diff is unique to those two models. The only thing that varies (depending on engine size) is the F.D. ratio. I've installed KLEEMANN LSD kits in every W215 and W220 model- 430, 500, 55, 600 and 65- they are all the same with the exception of F.D. Ratio. The Quaife will absolutely not work.
KLEEMANN's LSD is $945.00. Send me your diff, and I will install the LSD, and ensure backlash, etc. is set correctly- just pay shipping to and from. When you get it back, all you need to do is fill it with your preferred oil (anything GL-5 rated of the proper weight for your climate), bolt it in and drive.
030 performance package cars are the only ones that had an LSD from the factory (W215 and W220)- it's the same type (salisbury, 30% locking) as the SL65 uses. You can buy these from your local dealer if you have an 030 car's VIN number, but it will set you back around $4600.00. KLEEMANN is the only company who currently has an LSD for these cars.
Old 04-07-2011, 03:27 PM
  #40
Oxygen's Avatar
W220 S65 AMG
Gents, I apologize for the mis-information. I spoke to my friend in FL and he informed me that the LSD did not fit and he went with the Kleemann solution instead.
My bad...
Old 04-18-2011, 11:46 AM
  #41
Oxygen's Avatar
W220 S65 AMG
Old 04-18-2011, 02:52 PM
  #42
KLR CLS's Avatar
CLS63 PP
Definately a different Diff than other AMG;s
Old 04-22-2011, 11:43 PM
  #43
france2112's Avatar
Hi all. I get my car back tomorrow! I will report back after a day or two of driving it.
Larry
Old 04-23-2011, 06:27 PM
  #44
ShangoAshe's Avatar
2020 AMG GT-R PRO
can't wait to hear how you like the LSD!
make sure to do some decent burnouts just for the heck of it haha
Old 05-01-2011, 02:49 PM
  #45
buffyclk500's Avatar
clk500
any news
Old 05-02-2011, 12:42 AM
  #46
france2112's Avatar
Seems to hook up well
Originally Posted by buffyclk500
any news
Got my car back. First of all the power is amazing. did the Speedriven package upgrade: Larger intercoolers, scorpion intake, and ECU/TCU upgrade. Car is an absolute rocket!! Still spins on launch but appears to hook up better then before. Worth the money spent IMO. BTW, that picture in Oxygen's post is my LSD. He knows the tech that installed my mods and the LSD and it was e-mailed or text to him I suppose. LOL when I saw the picture. Small world.
Larry
Old 05-02-2011, 12:45 AM
  #47
france2112's Avatar
LOL, this is my differential!!! So far so good I think. Car has so much power that it spins no matter what. Without LSD I know it would be much worse based on my experience with a stock car.
Larry
Old 05-03-2011, 04:11 PM
  #48
waxking1's Avatar
CL65
So france2112,
What are you doing with all the power? Are you planning to take your car the the dragstrip?
I just installed the Speedriven ECU/TCU in my 65. I'm thinking about the intercoolers and maybe a LSD. I rarely am able to use the power I have now on the street. Our track is closed now, it is being resurfaced. I do plan to go when it reopens.
I only had the CL a couple of weeks before I installed the new software. I know it is quicker but it is really hard to quantify. This car is just so different feeling than my E55, the 55 felt faster but I'm not sure it was.
I think it would be really interesting to take it to the track and do runs with the stock program, then the standard 91/93 octane program, and then do a run with the 100 octane program. The trap speed should tell a lot.
I had a dyno scheduled last Saturday and was going to dyno the stock program and the 91/93 octane program but when I got to the shop they cancelled me. They said they had someone from out of town on the dyno and he was having trouble getting his tune right. Since I had two friends already on the way to watch and I had an appointment I was a bit irritated with this company. There is one other dyno shop local and I will probably try again when I get the time.
Old 09-26-2011, 05:37 PM
  #49
NRL
NRL's Avatar
CL65, FJ80, Sportsmobile 4x4, Model X Plaid
I got a feeler out to a reputable drivetrain specialist that have done other wavetrac installs on other Mercedes(E55) and Chryslers models.
I'll post up the result if wavetrac makes it for the CL65..
Kinda tired of just burning rubber to keep up with challenges on the street.. but esp comes on. It'd be over alot sooner if I could get the power down to the ground.
If it wasn't for esp, I'd be gone.. or in the ditch.
Anyone turn off ESP all the time?, I've keep forgetting to try it, that is turn it off.
Doesn't ESP still work if you turn it off, and still keep you from still going sideways abit if it's off?
Old 09-26-2011, 05:57 PM
  #50
saintz's Avatar
GL450
Yeah, you can't really turn ESP off, it basically just changes the allowed slip angle from none at all to a bit. The ESP is a real wet blanket, but agree, it keeps you out of the ditch. What we need is AWD like the Bentley GT. The new twin turbo CL550 4matic looks awesome.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: LSD on CL55 and CL65??
