CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Car at Speedriven :) More mods for the season
Old 09-27-2014, 02:02 PM
  #526
Thericker's Avatar
V12-Biturbo
Originally Posted by 320 dreamer
if the 60 ft goes down so does the mph . takes adding more power and traction to lower the 60 ft AND raise the mph
Exactly.. That new higher trap will unfortunately go back down...
Old 09-27-2014, 02:11 PM
  #527
Dr Matt's Avatar
05 CL65
Mph at 124 should get you an 11.0-1 with a good launch, but when you hook the mph will usually be lower. Given that your 60' was .3 off what it should be I'm going to guess 11.68.
Old 09-29-2014, 06:57 AM
  #528
V12Godspeed's Avatar
Your worst nightmare...
I am going to go with 11.4-.5 here. Get that 60 foot down! I really was going to go with what Dr. Matt said but we might as well throw all the .x out there. Lol
Old 09-29-2014, 11:56 AM
  #529
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
11.7x I have to double check exact time but as soon as I saw the slip I hid it in the glove box and started cursing lol
I will be back at the track soon with better tires to go at it again.
Old 09-29-2014, 07:29 PM
  #530
RaceHorse's Avatar
CL65
Listen, don't make yourself nuts and take it out on the car. Many of the V12tts with decent times did it in 40 degree weather with negative DA. You have the odds against you. Also, you can get a decent burn out and still spin 50-100 ft off the line with the open rear. I did it a bunch of times then just aborted the runs, that's the beauty of a track rental, turn around and do it again. This occurred on the same day I had 3 1.5x along with a 1.60 and 1.61. If you look at the last two slips I had good launch and good MPH, but only broke 11 seconds in one of them. (see link below) Its not that easy. Traction is half the battle finding some more power with cooler weather and negative DA will also be required. ...So I said 11.7x what do I win???
https://mbworld.org/forums/w211-amg/...ml#post5459950
Old 10-01-2014, 04:25 PM
  #531
I know what you mean, I waited 3 hours to get 2 runs in which were terrible to say the least. I now have some more issues with the car which I'm dealing with, hopefully next track day is sometime this weekend.
And as far as the prize goes I nominate you for MB WORLD's most knowledgeable member.
Old 10-01-2014, 05:40 PM
  #532
Dr Matt's Avatar
05 CL65
Good luck!
Old 10-07-2014, 04:58 PM
  #533
After last time out at the track my car started misfiring pretty bad. I just got word from Speedriven it needs a coil on the passenger side. I will order the coil today or tomorrow and get it here ASAP so I can go back and run the car. I'm starting to wonder if this also had me loosing power earlier when I ran the 11.2 pass. We should find out next week.
Old 10-07-2014, 05:43 PM
  #534
Thericker's Avatar
V12-Biturbo
Very doubtful.. As when coil starts to go etc you'll start w/misfires then limpmode etc Id be dumbfounded if any v12tt had coils starting to go at any point would you see 11.2 1/4 in dead heat of summer.. Remember Claytons perf running sl600 at MIR in great DA etc managed a BEST of 11.02 in 1/4.. His 600 was making 540-550whp & he ran very similar 60' to your 11.2 pass etc
Hopefully nxt week you'll see much cooler air & better DA w/same power as ur 11.2 & hopfully grab that elusive 10.99!
Old 10-10-2014, 03:49 PM
  #535
That is what I'm shooting for. Been at this for a while, set my goals high but kind of happy I'm not giving up. Im gonna crack the 600 stock turbo record no matter what happens, so I'm gearing up for the next track day.
Old 10-14-2014, 12:13 PM
  #536
Waiting for her parts
Car at Speedriven :) More mods for the season-rainyday_zps28f84720.jpg
Old 10-14-2014, 12:38 PM
  #537
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
What parts? You mentioned another coil went bad, but what other parts? Did you guys ever diagnose the MPH drop on the back half? That old timeslip makes me think you've dropped the car off for a tranny rebuild. You did mention a boost leak, but I think that was before the 11.7 run the other day. Either way, best of luck and I'm pulling for you to hit 10's.
Old 10-14-2014, 03:58 PM
  #538
Hey Grip,
Just Pass side ignition coil at this time, the car was dialed in a bit better last time out but had no traction at all. Ignition coil should be here sometime this week and hopefully I have some better traction this coming weekend at the track. I'm still going after the stock turbo record for the 600, seemed way easier to get earlier on, but I believe I can do it with a good sticky track next time out.
Old 11-10-2014, 11:15 AM
  #539
Ran the car again 2 weeks ago 2 runs both 11.3 one at 123MPH and one at 124MPH
Old 11-19-2014, 04:05 PM
  #540
Hey Guys,
Car is going in to Speedriven again this week, I have a vac leak somewhere on the door so it does not want to soft close. I will get that fixed since I'm trying to sell the car. The plan is to purchase a WideBody SL65 from another forum member so I'm working to get things rolling. My wife does not want me to have both, and in all honesty I would want the money out of the CL to go towards the SL65. I will have a new build thread once I start the work on the 65 (SPeedriven Big Turbo Work that is) I have been going back and forth if I should just do it to the CL since the platform is a bit better for a big trubo car.
I'm taking offers on my car you guys know on this thread what I did and what is going on with it.
The boost leak was resolved car is trapping 125mph, there is not a single thing you need on this car other than the big turbos and maybe a new trans. My trans is fine I was throwing boost that is why the trap was all messed up.
If the car does not sell this thread will continue and I will keep building, no matter what happens I'm still getting financing lined up for the 65.
Old 11-19-2014, 04:07 PM
  #541
Hey Grip,
The Coil was replaced car is running fine and hard now. No issues. Congrats on hitting that 11.0 pass, next time just push a bit on the wheel at the finish line for that 10.99 pass
Old 11-19-2014, 07:36 PM
  #542
RaceHorse's Avatar
CL65
Hey good luck with the sale, but realize these cars don't sell over night unless they are at a give away price. If you can swing both cars, you may be able to wait for the buyer who truly appreciates the car and is willing to pay closer to the asking price. Otherwise, you'll probably see a bunch of low ballers for sure.
Old 11-19-2014, 11:32 PM
  #543
True that I had 5 offers already for 18k prob another 5 at 19k and 2 at 20k which I passed. I won't give this car away, I rather keep it, car is too close to big turbos and by spring it will be paid for. I have the S550 to drive around daily and I'm in no need to get rid of it other than to build the next car.
Talked to Marcin from Speedriven for over an hour today there are many 600s out there for $15-$20k just not this one.
Old 11-20-2014, 10:31 AM
  #544
principledchiro's Avatar
2006 CL55 AMG
That's one sick lookin...butt kickin CL600. Imagine the sad face of those with newer muscle gittin whooped by that thing.
Old 11-20-2014, 06:59 PM
  #545
Old 11-21-2014, 10:07 AM
  #546
hyperion667's Avatar
Received 3,353 Likes on 2,807 Posts
2012 CLS63
selling your car??? you're a madman!!
goodluck, hope you get what you're seeking
Old 11-21-2014, 11:19 AM
  #547
Thanks, I rather give someone off this forum an amazing deal than give it awa to someone that will turn this car into a who knows what.
I'm open to offers, but please first take the time to read what this car has done and how much work went into it.
Old 11-22-2014, 12:04 PM
  #548
$22,000 for this thing guys. I know I'm not the one who should be saying this but this is a hell of a deal for this car.
Old 11-22-2014, 01:55 PM
  #549
Thericker's Avatar
V12-Biturbo
Kamil, pull the heavy stk seats, go run a 10.9x at Atco/MIR then post it w/the sale thread, bet that will add some interest to the gen speed freaks here
Old 11-22-2014, 11:17 PM
  #550
Im about to keep it and go all out on it lol
Quick Reply: Car at Speedriven :) More mods for the season
