I have solved the key housing swap delimma...
I have the exact same key as does "Burgca" for my W208, but it is in fact a W209 key. The prior owner had trouble finding a replacement key to fit the W208, so he resorted to replacing the entire Ignition Switch Starter Module with a W209 module so he could use a much easier to obtain W209 key. I've looked at the back of the module and it looks like the original wire harness plug was cut an replaced with a W209 plug. The W208 and W209 have the same number of plug terminals, but they are oriented differently, hence the replacing the w208 plug with the w209 plug. My guess is that the mechanic who was performing the new switch install had a W209 on his shelf and gave him a deal on it, but that's just a guess.
Alternatively, for those who wish to retaing their original W208 style key, whereas the keys themselves are scarce, finding keys with ignition switches is far more easily accomplished :
Here is a W208 ignition switch sold with key, and plenty more are available on Ebay:
http://www.ebay.com/itm/2001-MERCEDES-W208-CLK320-1-IGNITION-SWITCH-W-KEY-2105450208/221678300893?_trksid=p2054897.c100204.m3164&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140407115239%26meid%3Dc99c82da641143c8b27a2bea72df403b%26pid%3D100204%26rk%3D1%26rkt%3D30%26sd%3D140996795815
Here is the exact Ignition Switch Starter Module & Key I have in my W208, and it's clearly a W209 part. I suspect other W208 owners have also made the switch when they could not find replacements for W208 keys.
Available with both module & key for $150-$250US: Switch alone starts @ $50+
http://www.ebay.com/itm/03-2003-Mercedes-Benz-CLK500-Ignition-Switch-Module-W-Key-209-545-06-08-OEM-425/131433374222?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D28797%26meid%3D59e0ca35fb39479ca8d3b10414f32efb%26pid%3D100033%26rk%3D1%26rkt%3D4%26sd%3D131433374222
Hi etownbala / ALL,
I have looked on E-Bay (Australia & across the world), on Amazon, and across the internet, hence this post.
If you (or anyone else) can supply specific details of an example you have found for these older style (Series 1 - 1998-2001 - a208/w208 class) remotes, it would be appreciated.
This post is about the older style (Series 1 - 1998-2001 - a208/w208 class) remotes.
There are hundreds of examples of the later model 2002+ (details below) for sale on e-bay/amazon/etc.
However, I am yet to find one, for remotes relating to my (and I suspect numerous others) key/remote (Series 1 - 1998-2001 - a208/w208 class).
Mercedes-Benz CLK-Class
First generation (1998–2001; C208/A208)
Second generation (2002–2009; C209/A209)
Third generation (2010–present; C207/A207)
Can anyone please assist as to where I (and I suspect numerous others) might be able to source a new case for these older key/remotes.
key/remote for Series 1 - 1998-2001 - a208/w208 class Mercedes CLK Class cars
2000 CLK320 cabriolet
Hi Aussieuede,
Thanks very much for your detailed and specific information addressing the issue.
The information itself is very frustrating (in that you need to replace the whole module, because you can't find replacement key cases)
But it is, what it is....
I have 2 keys, one of which is in pretty bad condition, so I am not desperate yet.
But I have to say, that I expected that this (replacing the module and the key) may be the only way around the fact the you can't get new OEM cases for the Series 1 remotes.
Thanks for your assistance.
Way back when I ordered some key covers. I still have a brand new cover or two in the garage. I believe I may have ordered them from Amazon. They came sealed in Mercedes-Benz parts wrap, but I believe the part number may be wrong. The parts wrap has part number 1407602006 on it. I believe 1407602006 is for a whole key rather than a cover. At any rate, this is what the $12 cover looks like -
At Amazon, the description is for a 2009 Mercedes-Benz key cover. Having a 2009 MB in my driveway, I can assuredly state - that is not a 2009 key cover. That is the key cover for my 2002. The same covers are available on Ebay.
Hi MarcusF
There are hundreds of these (mostly Black and similar Black/Chrome) remote cases available on the net for the Second generation (2002–2009; C209/A209) cars.
Still can't find any for the earlier model (1996-2001)
2003 clk320 cabrio
i believe i may have solved your issue, bro.... do a google search on mercedes key model IYZ3302... there are many used ones on e-bay.... i would post a specific one but i think you can find it from there... or this website has it listed
http://www.keylessremotes4u.com/MERC...275C-P608.aspx
this site lists these models as compatible
1998 1999 2000 Mercedes C230
1998 1999 2000 Mercedes C280
1998 1999 2000 Mercedes C43
1998 1999 Mercedes CL500
1998 1999 Mercedes CL600
1998 1999 2000 2001 2002 Mercedes CLK200
1998 1999 2000 2001 2002 Mercedes CLK230
1998 1999 2000 2001 2002 Mercedes CLK320
1999 2000 2001 2002 CLK430
2001 2002 Mercesdes CLK55
1998 1999 Mercedes E300D
1998 1999 2000 2001 2002 Mercedes E320
1998 1999 2000 2001 2002 Mercedes E430
1999 2000 2001 2002 Mercedes E55
1998 1999 Mercedes S320
1998 1999 Mercedes S420
1998 1999 Mercedes S500
1998 1999 Mercedes S600
#32
Hi All,
An update on trying to find a replacement key shell.
This ended up being a 3 part process.
1. Purchased a new key blade from the USA via E-Bay
(http://www.ebay.com.au/itm/MERCEDES-...item20eec559ec)
2. Purchased a 2nd hand remote from the USA via E-Bay (http://www.ebay.com.au/sch/m.html?_o...Z3302&_sacat=0)
3. Got the new key blade cut to suit my car (based on my original key) at a local locksmith.
The 2nd hand remote had existing electronics which I removed and replaced with the electronics from my original remote (as all I really needed was a new remote shell)
I did have a key, however it was broken at the key loop so I replaced it at the same time.
It appears that you can't get new replacement key shells for the older series 1 Mercedes remotes, but a good 2nd hand one does the job.
Thanks all for your assistance.
#33
W209, W124
http://www.ebay.com/itm/Keyless-Smar...hV8AQb&vxp=mtr
Just search for 1yx3302 on Ebay, several sellers
