need help with vent for heat/ air conditioning
Old 08-17-2008, 01:36 AM
enyce284's Avatar
1998 CLK 320
when i turn the a/c or heat on it only comes out from the left and right vents and the vent by the windshield it doesnt come from under the dash (by your feet) or the middle vent above the climate control anyone know what this can be and how to fix it please reply or pm me ive been looking for the answer for a very long time and still cant find out please help!!
Old 08-17-2008, 09:28 AM
Discgolfer74's Avatar
2003 CLK500
I have the opposite problem, it only comes out under the dash, but won't change to anything else.
I talked it over with my buddy at MB, and he said it could be one of two parts in the heater box. One part (aprox. $120) controls the flaps(?) and is fairly easy to get to. The other part (aprox. $30) are the clips that hold/pivot the flaps (which can easily break) are deep in the heater box, and hard to get to.
Of course it has to work like that. Cheap=Complicated or Pricey=Easy. Where do you start?
They can give you a nice printout at the parts department to see what they are and how to get to them, but I wouldn't feel comfortable doing it myself. I'll look around to see if I still have the part numbers.
Good Luck!
Old 08-19-2008, 07:24 PM
rjlawlor646's Avatar
2001 CLK 320
yea i have that problem...the vents above the radio and center console wont blow with heat but will with a/c..its wierd
Old 11-03-2010, 08:47 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
^^^^^same here. i check it everything even the vacuum lines and nada.
its frustrating. I froze this morning and it was 32 degree
Old 11-04-2010, 02:14 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
check the thin white pipe at the back of the engine. it is the supply for the vacume to the control flaps. if you have a problem with your motor mounts the motor moves and the tube becomes disconnected
Old 11-04-2010, 02:28 PM
^ that i already checked.. its above the throttle body.
mine every thing works but only when go higher than 68, it wont send heat from center vents.
i know some manuals from the dealer, it states that NO HEAT whatsoever should come out from center vent.. but in my case, it did but it stopped suddently
Quick Reply: need help with vent for heat/ air conditioning
