Confused on Spark Plug & Wires Resistance Issues.
2000 CLK430 Cabriolet
Regarding my year 2000 430CLK Cabriolet.
Confused on Spark Plug & Wires Resistance Issues. I have read plenty of postings on the resistance issues of wire/plugs, relevant to the model year of the vehicle, and am confused-need some clarification.
Seems it is time for me to change my plugs again. Changed them last about 50K miles ago. At that time I used Bosch FR8DPP33 (the original F8DPP332 plug was no longer available), and did NOT change the plug wires. Today, I still have the original plug wires that came with the new car 114,000 miles ago.
Here is what I would like to know.
Was the original configuration on my car non-resistor plugs, and resistor wires?
Is the FR8DPP33 a resistor plug?
If both answers are yes, then it seems that I must have doubled the resistance when I changed the plugs, likely affecting the spark. Oh well.
Keeping this resistance issued in mind, for this new plug & wire job, what plugs and wires would one recommend, short of the pricey Denso wire sets? Would prefer wires in the $200 range. Specific part #s of plugs and wires would be helpful.
Again, I would appreciate your advice.
2013 FIAT Abarth 500
No idea on the resistor part you're talking about -- doubt it's that complicated as many people pair varying plugs and wires and don't run into issues.
For simplicity sake, I'd just stick with OEM - the Bosch plugs you already purchased and wires. I would just order the complete Bosch wire set (part # 09850).
Yes, I know, I know. The "r" in FR8DPP33+ designates is a resistor plug. Resistor plug and resistor wires equal increased resistance, equal diminished spark. Vehicle was designed with non-resistor plug and resistor wires. OEM wires for this vehicle remain resistor wires. Am looking for a solution--a solution, ie. does anyone have experience, a source, etc., with alternate non-resistor plugs.
2002 CLK 430, 2006 E320 CDI
I'm obviously digging up an old thread here! I have a new to me 2002 CLK 430, like new condition with 57,000 miles. The original owner doesn't remember having any type of ignition "tune-up", and it has Bosch # F8 DPR Plugs, that say "R1 282" on the ceramic portion. The wires are Mercedes part # 112 150 04 18. Both appear to be original. So... what's the consensus of this? I don't want to double the resistance either....
I think that due to age, I need to replace at least the plugs.
Thanks!
Thanks!
My Yr. 2000 430CLK (W208):
No alternative but to use resistor plug & resistor wires.
Plugs: FR8DPP33+ Torque: 28 NM Reseat Twice to compress plug washer.
16 spark plugs, Bosch FR8DPP33 $123.40 ebay
Wire set: OEM is Bosch # W0133-1829574 (alternate part# 09850)
$167.89 www.rockauto.com BOSCH Part # 09850
My instructional on plugs install:
https://mbworld.org/forums/clk-class...gs-430clk.html
My instructional on wire set install:
https://mbworld.org/forums/clk-class...wires-set.html
shadenfroh (11-09-2016)
