Electrical issues after disconnecting battery on 2000 CLK430
2006 CLS55
Sent this post over for my brother
Hello!
I disconnected the negative post on my battery on my 2000 CLK430, now I have an ABS and BAS warning light on and the windows will not roll up, Can anyone please assist with this? Prior to this there were no issues. Thanks!
Shawn
Hello!
Shawn
Turn your car on, turn steering wheel from lock to lock a few times, then roll ur windows up one at a time and when they're up hold the switch in the up position for another 3 seconds
Just drive the car a few feet and apply the brakes to get rid of the warning lights on the dash, it has to detect you ABS sensors and calibrate. I freaked out too the first time.
99CLK320,
after 15 years my oem battery headed south. tried to start it and just got a click so I hooked up the charger and it started right up. Question: has anyone hooked up a charger under the hood for a 2amp maintenance charge then pulled the battery? This should prevent the whole re-sync windows, sunroof and seats, no? My thinking is; as long as there is juice to the computer no reset is needed, eh. TIA DB
I respectfully disagree...hook a charger onto the engine bay jump start terminal and onto a good ground.....pull battery and no resync needs to be done.
be careful when disconnecting battery that you don't rest the terminals on anything...sparks will fly!
