Interior 'dome' light intermittent
Old 08-06-2011, 08:09 PM
marinabay's Avatar
clk500
I have a 2005 clk500 with the following issues
1. The dome light only comes on sometimes when door opened/when key taken out of ignition. The switch is in the correct position so don't know what is causing this
2. I can't open the top part of the centre arm rest (it seems to be locked but key will not open it)
Old 08-08-2011, 10:43 PM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
1. Sounds normal? Unless you really mean only turns on when opening door/releasing key. Switch in center position? Or is it on the way left?
Old 08-08-2011, 10:52 PM
marinabay's Avatar
clk500
Sorry if I was not clear, what I mean is the light does not always go on when key removed (as it should) or when remote key unlocks doors. The switch is in the correct position.
Old 08-08-2011, 11:20 PM
I would check the fuse for the dorm light or check the bulb for the dorm light (might be burning out or may not be OEM bulbs). I know my aftermarket dorm lights don't always turn on either.
Quick Reply: Interior 'dome' light intermittent
