Xenon d2s replacement
2018 E43 | 2017 GLS450 | 2004 CLK 500
hi all, I did a search but just wanted to confirm before I damage anything. I can barely see what I'm doing, let enough get my hand in there. After i twist off the power harness - it sounds like there's a metal clip holding the bulb in place. So does that clip:
a. slide off to the side
b. does the bulb then pull right off?
thanks.
thanks.
clk, Lexus RX 350
hey question. So the high beams i'm replacing with sylvania ultras so I get the white bulb look dont want high beam HIDs and also i have factory xenons with factory ballast can i just switch the factory hid bulb with a 6000k bulb? or i have to swap the entire unit? also if i just swap the bulb anyone know a good place to just get the hid xenon bulb?
04 CLK 320 > CLK32K
Honestly, I'm not even sure anymore. I think facelift is D1S and pre-facelift is D2S. Take a look at the base of your bulb. If the base is square you have D1S, if it's round it's D2S. I have a set of D2S 6000k lying around if you need them.
I'll check and let u know...just have to wait til the snow melting...i couldnt open my garage doors lolz.
Hah hah - thanks fellas. I was moving slow. What they did was they attached a camera on a rig which attaches to the car with 2 suction devices. We then drove the car slow - no more than 5 mph while thd camera shutter is ke
clk, Lexus RX 350
wait so if i want to change my high beam bulb in the 2005 clk i have to use ds2 bulbs? sylvania bulb guide says use H7 because i want replace the yellow high beam with sylvania ultras for the white look without HIDs and ballasts.
2004 E500 4Matic
Hi guys,
I'm thinking of getting these bulbs from HIDextra and I see few of you did that already.
So, what do you think about them?
How long did you have them?
Any issues with the projectors or the ballasts?
Basically are they safe to use in our cars or they will damage something else way more expensive?
I don't want to save a little on the bulb price to end up paying so much more to replace the ballasts or anything else ...
Please let me know, thanks!!
