Please check my VIN for Balance shaft issue?
#926
Good morning, Today I started up my car to see the P0015 error code. Does it come and go? For some reason, with the Bluetooth OBD2 thing I have it will not let me reset the codes and turn off the light. My VIN is WDBTK72F58T090966
Where does my car fit in the grand scheme of things? Hopefully beyond the problems....
Thank you so much in advance,
Jeff B
Jeff B
#927
MBworld Guru
Well, with a MY2006 M272 engine, it's in the range, and those codes are the tell-tale symptom, so I'd say the timing chain idler sprocket on your balance shaft is deteriorating. If you have a really good relationship with your MBZ dealer, you might get some help from them and MBUSA under their "goodwill" policy, but otherwise, you are likely on your own. Dealer rices ar $4K-$5K for the job, but you may find an indy who will do it for less.
#928
I had the codes p0016 and p0017 pop up.. tried to erase them but they won't go away.. anyone ever have this problem? Is it something i can fix myself? vin number WDBTJ56H96F186534 . Any help or guidance will be appreciated.
#929
#930
Looking at '08 R350
We have an 07 R350 we're ditching due to the balance shaft issue. But LOVE this model.
Considering an '08. Vin 4JGCB65E98A084755.
Should we go for it?
Are there any other issues that should steer us away from this car?
#931
MBworld Guru
#932
MBworld Guru
My vin number is WDBTK56F58F234710
#933
MBworld Guru
#934
1/2 of an entire model year's engines affected and no recourse with the manufacturer? I read that the class action suit in NJ was tossed and from what I can gather on the internet, the suit in CA is still in process but for the M272 engine only because the plaintiffs vehicles did not have M273 engines. And MB want the CA plaintiffs included in the NJ suit.
If anyone has addl info regarding the class action, it'd be good to know.
#935
#936
does anyone know of a bypass that i can turn off the light so i can at least pass inspection? i was wondering if pulled the sensor out, disconnect the batt for a while and just let it sit without plugging it back in would the light come back on.
#937
MBworld Guru
SDS can disable the MIL, but it also won't illuminate during starting, which I suppose that your inspector will look for (in order to make certain that the light is functional)
#938
W211 E350, R170 SLK230
Thank you Rudeney for all the information.
I'm trying to help the forum understand a couple things so correct me if i'm wrong. If I misinterpreted it, correct me please.
Step 1:
Run the VIN on this site http://www.neoriginal.ru/cat/mb/
(use google translate to change Russian to English or whichever you prefer)
Step 2: Look at the output below:
E 350
Description of the model: E SEDAN
Model Code: 211,056
Catalog: 65H
Engine: 272 964 30 340 963 <<here is the relevant information
Conditions for affected engine(s) are:
272 30 468993 and below
273 30 088611 and below
-If codes P0016 & P0017 show up on OBD II reader, then you will most likely have the balance shaft issue, if not, then you might need to replace the magnets
-Issues most likely to occur prior to 100k Miles
-Some MB dealers may or may not honor of "goodwill repair"
Added notes:
NJ lawsuit - MB wins
CA lawsuit - still in effect? where can we find updates for this?
Step 1:
E 350
Model Code: 211,056
Catalog: 65H
Added notes:
#939
MBworld Guru
That pretty much sums it up. Note that OBDII codes P0017 and P0016 are generic codes that actually translate to more than one (each) MBZ DTC. Its DTCs 1200 and 1208 that are the balance shaft symptoms, do before declaring it so, use the visual inspection method:
http://www.benzworld.org/forums/w203...detection.html
Also, 100K problem-free miles is not an all-clear. There are reports of failures after that. It's possible that ALL of the engines in the range are defective, it just depends on how quickly they fail. Since the engines in question are only between 8 and 10 years old, we aren't seeing any with really high mileage (say 200K+). Of course all of these sprockets in any car will eventually fail (nothing lasts forever!).
#940
Please Check This VIN
I am interested in purchasing an MB C230 2007 but recently read about the balance shaft issues in certain engine serial numbers.
The VIN is:
WDBRF52H07F839481
Thanks4
The VIN is:
WDBRF52H07F839481
Thanks4
#941
MBworld Guru
The VIN is:
WDBRF52H07F839481
Thanks4
The VIN is:
WDBRF52H07F839481
Thanks4
#942
2006 C280 4Matic
#943
MBworld Guru
#944
Hi Rodney
Kindly check VIN# 4JGBB86E56A137499 for balance shaft and magnet issues. Fingers crossed. Thx.
#946
MBworld Guru
Hi Rodney
#947
MBworld Guru
#948
Balance shaft issue
Please check my VIN #: WDBRF52HX7F935764
After checking the site shown above this is what I got
C 230
Описание модели: C-СЕДАН
Код модели: 203.052
Каталог: 69N
Двигатель: 272920 30 607182
Трансмиссия: 722998 01 133733
Передняя ось: AL273170254636
Номер заказа: 0770464533
Номер продукта: 1576565
Интерьер: 141A
Цвет: 775U (ИРИДИЙ СЕРЕБРИСТЫЙ - КРАСКА METALLIC)
Дата: 070228
Список опций
Перейти в каталог
If I interpret correctly, I'm NOT at risk. Correct?
C 230
Код модели: 203.052
Каталог: 69N
Интерьер: 141A
Дата: 070228
Список опций
Перейти в каталог
#949
#950
PURCHASED - SLK 200 YR 2008 - UPGRADE - Australia - Can I get vin check pleasee
Hello ALL
How exciting - I finally bought my dream car! WOW Factor. Its so beautiful.
Firstly, her name is "Strudelum yum: - ha!
Gun metal - with red trimmings inside with only 69000 km on the clock. Shes in perfect condition, interior and exterior. She has just enough power for my liking. No prob with the convertible, she drives like a dream - all up to date on services by MB
After much research and several test drives, I decided on the SLK 200.
The SLK 350 is awesome but just a little too powerful for me.
I do have some questions though. I love all the features on the SLK, but is there a setting to tell me just how many kms I have left (reserve level) the manual says 9 litres??? the reserve level flashes just a little under the quarter mark, surely you have more than 9 litres left? right?
Bluetooth - its blue tooth ready, however the car did not come with the puck. I've researched on line, and my goodness there almost $400! Any body selling 1? am willing to buy.
Rear vision mirror - according to hubby its big and blocks out a lot of the windscreen, is there an aftermarket slim version? I don't think its that bad, but the MAN does.
The brake calipers are grey/white - yuk. If I have them colour coated will this void warranty? I will ring the warranty company, just thought that all you guru's out there would know a lot about this stuff.
And the dreaded question for Rodney is, does my car fall into potential car problems - WDB 1714452F201472
Also, any cheat codes out there ? i.e resetting options etc.
Thanking you all in advance
Cheers
Mercedes
Cheers
Mercedes
