Please check my VIN for Balance shaft issue?
#876
2007 CLK350 Cabriolet
#879
SLK 280 2007 - Australia
Hi Everyone
Next week I will be purchasing my SLK280 yr 2007
Can my vin number be checked to see if it falls within the bad or good range
WDB1714542F115896
Fingers crossed....
Cheers
Benz
WDB1714542F115896
Fingers crossed....
Cheers
Benz
#880
MBworld Guru
#881
Hi, would you be so kind to check about this one if its falls into the issue? Im supposed to buy the car within the next day, but now im worried, since this is my first MB car and its used 2007 c230.
WDBRF52H97F839544
When I googled it, I am not sure (so please double check), but the engine of what i want to buy seems to be:
272920 30 396475
WDBRF52H97F839544
272920 30 396475
#882
Thank you so much. I realise every car/model no matter what you buy could have potential problems. I have done some research ( I'm in Australia)
One thing I didn't ask the dealer, is if the car has been recalled. Should I do this??? or perhaps I should ring MB and ask them.
Cheers
Benz
Cheers
Benz
#884
MBworld Guru
#886
What a helpful tread. Rudeney can you also please check my car?
Here is Vin: WDBTK56G47F207134
07 clk 350 cabio
07 clk 350 cabio
#887
MBworld Guru
07 clk 350 cabio
07 clk 350 cabio
#888
Please can you check out vin Wdbwk56f55f032345---it is the VIN of a slk 350 I am ready to purchase. have a feeling it is in the potential problem range. about what % of those cars have failures? if a car was very well maintained and has 80,000 miles with no current problems, is it still possible it can fail at any time without much warning?
#889
MBworld Guru
I can tell you with 100% certainty that a MY2005 CLK350 will have an engine "in the range". In fact, the SLK was the first model to get the M272. All M272 and M273 engine through MY2006 are in the range. It's only MY2007 that may or may not be as that was when the problem part was corrected.
#890
1 Post
2008 e350 4Matic-2007 Gl320
Hi, I am new here. I am just learning about this balance shaft issue as I had a code related to cam shaft sensors. I am being told it is not the balance shaft issue, but I am certainly concerned. Would you be kind enough to tell me if my 2008 E350 is in "the range"?
VIN WDBUF87X18B222336 (corrected VIN number. Had an extra B
Thanks in advance.
corrected VIN number WDBUF87X18B222336
Thanks in advance.
#891
MBworld Guru
Thanks in advance.
Thanks in advance.
#892
2008 ML320 (W164) - 201K Miles
Hi Rodney
Can you please my car is affected with this issue ? VIN: 4JGBB86E68A308649
#893
#894
MBworld Guru
Hi Rodney
#895
MBworld Guru
#896
Rodney, you king among men,
Could you check 4JGBB8657A257191 for me?
Also, how prevalent are the valve conductor issues and front diff issues on 2007 ML350s? I'm looking to buy one with 60k miles and will be using it quite a bit for light towing.
Thanks!
Thanks!
#897
I have been considering purchasing a 2007 CLK350, but I'm not really interested in upgrading from what I have to a potential money pit.
Rodney, would you be so kind as to check WDBTJ56HX7F208509 for me? Thanks much.
#898
MBworld Guru
4JGBB86E57A257191
If that's correct, then it has M272 engine #603288, which is beyond the balance shaft problem range.
#899
MBworld Guru
#900
