Suspension sounds when cold
2007 BMW 550i
Even since the tempertaure went down here (2-3 weeks), ive been having a weird problem. The suspension makes knocking sounds like crazy front and back as if the ball joints are about to break but after 15 min of driving the sounds go away. The car passed government tests just a week ago with flying colors and they used machines that move around the wheel to stress joints and nothing came up. Car was also completely tested, including suspenion, a couple days before the tempurature went down and nothing was wrong then. Opinions?
MBworld Guru
Front noise is typically from the anti-sway bar bushings. On the older design, they were replaceable (very inexpensive and easy DIY), but the newer design has them permanently glued to the anti-sway bar and the proper fix is to lubricate where they contact the clamps. The problem is, even with lubrication, the rubber bushings will harden. I replaced mine with the old-style bushings (I had to scrape the glued-on bushing off the bar with a razor blade) and they've been fine. Rear noise is probably bad bushings on the thrust arms which will likely need replacement to correct.
MB W212, MB W218, BMW F06, BMW F48
My wife's CLK500 makes a solid thumping bass sound like (ddadada dadddaa) everytime she hits a bump or uneven pavement and that annoying sound is coming from the rear passenger side behind the back seat. I also noticed that when someone is sitting in the back seat or when her trunk compartment is full of stuff, it makes that sound constantly. What do you guys think it is?
2007 BMW 550i
My wife CLK makes a solid thumping bass sound everytime she hits a bump or uneven pavement and the annoying sound is coming from the rear passenger side behind the back seat. I also noticed that when someone is sitting in the back seat or when my trunk compartment is full of stuff, it makes that sound constantly. What do you guys think it is?
After I replaced my shocks and springs with aftermarket parts (Bilstein and Eibach), I heard the first "squeak" when exiting the freeway. I've probably had the new suspension on for 700 miles. Is this ok?
2007 BMW 550i
Well I can tell you I was getting squeaking sounds and I tried everything to fix it. I first thought it was the shocks or the antiroll bar bushings. I had changed both because they were gone anyway and still it squeaked when going up an incline with the wheel turned. My mechanic injected all the ball joints in my car with some type of grease. its been great ever since. guess maybe the joints have dried up.
MBworld Guru
I would not use penetrating oil on ball joints - it's too thin. They need proper grease. Unfortunately, they are sealed and not designed to be lubricated beyond the factory assembly, so there is no official grease for them. Some people have found a way to lift the rubber dust cup and get some grease int here, so If you do that, I'd use a standard lithium suspension grease.
2007 BMW 550i
Well it worked fine with me. He injected a bit using a needle now it doesn't creak anymore.
My mechanic injected some of that oil too using a thin needle and the sounds from the front went away. I get minor sounds when cold from the back, but that is because of the bushings. I'll replace them soon.
