Blinker Side Mirror
Old 04-06-2015, 09:39 AM
mis3's Avatar
2004 CLK320
Blinker Side Mirror
How do I remove the side mirror blinker?
Are they instructions somewhere in this forum?
Old 04-06-2015, 10:47 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
They snap right in. Pry it off from the outter edge.
Old 04-06-2015, 08:11 PM
mis3's Avatar
2004 CLK320
So, the blinker is secured by clips. Where are the clips?
I went to an online store to look at the parts, unfortunately,the picture does not show the locations of the clips.
Old 04-07-2015, 10:11 AM
megacrazy's Avatar
Just pull on the outer edge:
Old 04-07-2015, 10:44 AM
mis3's Avatar
2004 CLK320
Thanks.
I see 2 connections, one at the end (near the window) and one near the outer edge. The one near the outer edge seems difficult to connect. I will try.
Old 04-07-2015, 10:47 AM
megacrazy's Avatar
The only connection is towards the window. You basically pop it out starting at the outer edge then pull it towards you to unplug it (away from the window). Just go pull on it haha. It comes off without any tools.
Old 04-07-2015, 10:56 AM
mis3's Avatar
2004 CLK320
Thanks. I don't really have to remove the whole blinker. I see a brown spot inside and I just want to clean it up. Not sure if this is rust, the side mirror housing should be plastic.
Old 10-09-2015, 07:59 PM
Shrumsjs's Avatar
2015 GLK350 108k miles2008 clk350 Cab 180k miles. 1998 E300TD 237k miles
no No No, there is a screw holding it in. You tilt the glass foward at the top the remove the retaining wired holding the glass in. Three T10 screws hold the mirror moto in place. Removing them will expose the one T10 screw holding the light. If you try to pry it out you will break the fixture. The previouse writer it talking about the marker light not the mirror light. Just repaired my mirror and now know how it works. Dealer wanted $150 for mirror with back blare, purchases glass and gluded it in doe $15 buck.
Old 10-12-2015, 09:33 AM
eteller's Avatar
2009 CLK 350
Just did this, there is a screw that goes in the hole on the left side of your picture!
Old 10-14-2015, 09:32 AM
megacrazy's Avatar
Hahahah what hole and what screw? I'll post a video tonight of me ripping it off my mirror without tools.
Jokes aside...maybe a design change over the years?
Old 10-14-2015, 10:26 AM
eteller's Avatar
2009 CLK 350
May have been a change but on mine there's a tiny torx screw that goes in the hole marked in the pic. Was a **** to get lined back up.
Old 10-14-2015, 10:42 AM
megacrazy's Avatar
Hmm ok. I'll take a picture later so we can clarify this. Maybe they added the screw so they're not so easy to steal. That seems like a pain to get to.
Quick Reply: Blinker Side Mirror
