OverDrive's CLK55 to Black Series Wide-body Conversion
#78
Did you get any rubbing on the arches after they were rolled and the spacers put on? I've just done this and it rubs a bit, but only when there's like 3-4 people in, I'm hoping the coilovers sort it out.
#80
Volvo
Initial there was some rubbing right after the kit was installed however with some fine tweaking (Sanding down and banging a few edges inside the wheel well, I haven't had a problem since. I am currently running Bilstein pss9s.
#83
What's the material for the Prior Design kit? Is it fiberglass? The price I'm seeing for this kit is approaching OEM parts so I'm wondering what the quality is.
#84
Hi there, how was the handling with w204 hubs? Have you put some bigger spacers in the rear? I am searching for info on this setup. Have you heard anything on R230 (SL500) susspension swap?
#85
Volvo
From my past experience with aftermarket body parts, I found the Prior Design kit pretty top notch. You did have to adjust it slightly when it was bolted to the car but there isn't any cracking/flexing going on.
As most know now, I no longer own this car as I have sold it to another forum member. I'll let him post an update on it once he is ready, but I never got around on using the w204 hubs. I did my research on it though. You can only use them in the front (any w204 hubs work) which would eliminate the 30mm spacers that I have on it currently. They would give the car between a 30-40mm look which is perfect for this body kit in the front.
#86
