AZN Optics - CLS Storefront
#51
SPONSOR/MBworld Guru
According to my spec, all 2006 rear tail lights have integrated LED signals? If that's not the case and you have a replaceable bulb, can you pull out the stock bulb, take a few pics of the base of the bulb so I can identify it and email to me at aznoptics@gmail.com and I'll see what I can do.
#57
Nope, it's an ugly yellow bulb. LED's came out in 08+ I believe.
It's a big job to get to I've heard; I'd like to only take it apart once I have the replacement bulb in hand. Can you please research?
#58
#59
It looks like your rear tail light bulb is soldered in and would take a decent amount of effort to remove. No where I've seen lists what bulb is removed as most give up it seems once they see that the bulb is attached to the assembly bracket.
https://mbworld.org/forums/cls-coupe...ght-bulbs.html
#60
CLS63
Afternoon AZN. I just picked up an '09 CLS550 last week. Haven't been on the site in a while. Bought some lights a while back from you for my '08 C350 and was very happy. Looking around this site and yours, it seems that the direct plug ins and quality of LEDs has increased all around. Looking for LED plug ins for my driving lights, and plate lights. Also could use a referral for AMG floor mats (dealer quoted me 771 dollars !! ) Please PM me with info. Thanks.
#63
We have these in 5000K pure white:
http://www.aznoptics.com/index.php?m...&products_id=8
or 8000K white with a slight bluish hue:
http://www.aznoptics.com/index.php?m...&products_id=9
#64
As you all know, AZN Optics is always looking out for new innovations and designs in the market to bring you the best option available for your w204. We've just released a spin off our older V2 model which we're calling V2.5. This design incorporates a capacitor to help regulate power as well as a physical cut PCB to help reduce heat transfer to more delicate diode components. Few other component improvements as well.
#66
I have a brand new set (2) 5000K 194 wedge LEDs from AZNoptics.com
Purchased them last week but decided not to use and they don't accept returns.
$15 shipped to lower 48 States.
#67
Hi Michael,
Just want to say thanks for sending out my order so fast (arrived in 7 days to Canada). I ordered 2 D2S 5000k Morimoto HID bulbs and they are the perfect colour, so are the plate LED lights. For anyone sitting on the fence thinking if they should order from AZN Optics, go ahead. He answered every question I had, which was quite a few
#70
Formally announcing that all our V3 units have not been adapted with Gel Packs. This is a high temp resistant gel substrate that we've applied to the resistor and critical solder joint to both help encapsulate the heat and insulate against heat soak, making these units more durable against heat and electrical surge related incidents.
#72
bump. We'll be introducing a new line of H7 and H11 plasma LEDs in the next few weeks. These would be ideal for fog lights if you don't want to upgrade to HIDs. Package will be put together with big Morimoto load resistors.
#74
Please email me at inlukk@gmail.com when the H7 fogs become available and price etc.
John
John
#75
Need of another set of Festoons...36mm or 38mm
Thoughts......36mm or 38mm 6418 bulbs for my wife's W219. On the first set we had, one of the bulbs began flashing just this past week, they were 36mm. Any suggestions...?
