problem locking plus upgrades
cls 500
Hello. I have a 2005 CLS 500 with the factory fitted AMG body kit etc. It has the keyless start with a push button on gearstick, and keyless entry.
However for the past month I am not always able to lock the car either by using either key fob or by pressing the button on the handle. Usually I would press the door button on drivers side (the other ones never worked, or arnt set?) and all the doors would lock. Now about 25% of the time it works, the rest it wont. The keys will only work to unlock, when I push on either key they unlock the car but lock will not work. Any thoughts?
Also. I am new to this forum and car. I bought it in November. Usually I change my car every year but I like this one and want to upgrade it. I've bought custom rims, custom exhaust. What other things can I do? any internal mods out there? I like toys and gadgets. Also any ways of getting more out of the engine without risk of damaging or shorting the lifespan? Thanks in advance
cls 500
the other doors never worked, although i am wondering if thats something in the settings. But would that explain why the remote lock never works? (from either key)
If you have Keyless option in your car and i assume that you do then Any of 4 door handles is able to lock and unlock the door .If all of them went bad may be this is where you have to start. I have driver door handle that needs to be replaced but i am too lazy to do it, i am using my rear door handle to unlock the car i usually have to open it anyway to put my briefcase there .
Also did you replaced battery in key fob with new ones ?
cls 500
well i solved it. Yes of course changing the batteries was first thing I did. The keys looked a bit tacky so I ordered a new one for 300 euros. when it arrived everything worked again. I guess there was a malfunction in the previous two keys, they were very worn. everyone working now. thanks
cls 500
Well i have to say this is the worst car I had, sold it now but to cut a long story short within 4 months I had the following problems.
- front suspension failed
- back door catch needed replacing as door wouldnt close
- front passenger door window motor needed replacing
- Engine water pump failed
- main screen and buttons in middle failed, had to be reset twice
- strange sound from rear
- alternator belt needed replacing
- sunroof wouldnt open
- controls for driver seat, the top button stopped working
- Exhaust needed replacing
I sold the car in the end to cut my losses. It had arond 70k miles which is nothing. Bought a BMW750i with 90k miles, had it a couple of months and not one problem and everything works. I think Skoda is better than the mercedes cls.
