Code P22A1; R350 BlueTEC
Old 02-05-2017, 09:24 AM
SndsoftheSbrbs's Avatar
2019 Audi Q8, 2017 Porsche Cayenne S, 2015 GL63, & 2005 E500W4
Exclamation Code P22A1; R350 BlueTEC
My check engine light came on. My code reader gave me a code P22A1. I cannot find much information on it. It is not listed under Mercedes-Benz codes that I have found. My code reader indicates that it is related to the nitrogen oxide sensor. Any thoughts?
http://obdii.pro/en/code/P22A1
Old 02-05-2017, 04:03 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Change your NOX sensor and live long and prosper----A question there is a scammer on one of the auto dating sites advising folks to purchase(group) a Polish scanner---did you purchase one of those scanners??
Post your VIN for the correct part number!
SndsoftheSbrbs (02-05-2017)
Old 02-05-2017, 04:08 PM
I purchased my Autel from Amazon.
Old 02-08-2017, 05:48 PM
My mechanic says that it is not that simple. He says that it is a difficult problem to diagnose, meaning that it might not only be the sensor.
Old 02-14-2017, 06:43 PM
I am currently in for about $2,000 in repairs related to this NOx sensor. Apparently, there is still no guarantee that it will fix the problem.
Old 02-15-2017, 07:29 AM
Plutoe's Avatar
1999 E300TD
It's not that simple because you and your mechanic have inferior diagnostic equipment---find someone who has DAS Xentry or equal and you will solve your problem!!
Old 02-15-2017, 11:11 AM
kajtek1's Avatar
Received 1,730 Likes on 1,380 Posts
1922 Ford Model T / no OBD
No it is not that simple.
Bare in mind Yoni, that you are taking the advice from "specialist" who says his 300 diesel does not have wastegate.
Have no idea where you could put the $2000 but it looks pretty simple on video.
Old 02-17-2017, 07:54 PM
I got my baby back. She had her NOx sensors replaced and camshaft position sensor replaced. Unfortunately, it looks like the timing chain and tensioners will need to be replaced in the near future.
Quick Reply: Code P22A1; R350 BlueTEC
