definitive wheel fitment guide for w124 pdf
Rating: Thread Rating: 7 votes, 5.00 average.
Old 02-05-2013, 03:59 PM
  #76
XJguy's Avatar
94 E320 Coupe
Originally Posted by stormtigers
Without knowing what year it is my first answer would be NO.
Later model MB's have M14x1.5 bolt thread ! W124 is M12x1.5 bolt thread.
You would need adapter plate to fit
Thanks for the reply
This is the wheel, supposedly came on 01-02 CL600
Old 02-06-2013, 11:12 AM
  #77
edcarls's Avatar
97R129-01W163-94E320-93500E
The difference between M14 and M12 bolt is that M14 bolt is larger than M12 by 2MM. If the wheel uses M14 bolt the hole would be larger by 2mm compared to wheels that uses M12 bolt hole. But, since the wheels are hub-centric and the bolts had ball seat, it would fit because the hub-centric wheel would mate centered to the hub and the ball seat of the M12 bolts will also mate centered on the M14 wheel hole.
Your main concern should be the width and offset of the wheels.
Good Luck!
Old 02-06-2013, 03:26 PM
  #78
AMGDave's Avatar
300D, 500E, E420
If you use factory wheels with M14 bolt holes, you need to use custom wheel bolts, that have M12 thread but with M14 ball seat. The M12 lug bolt ball seat is smaller and SHOULD NOT be used with M14 holes as the size & shape of the contact area is different.
The hybrid bolts are available from this vendor:
http://www.radusadirect.com/category...l_seat.m12x15/
Old 02-06-2013, 03:47 PM
  #79
XJguy's Avatar
94 E320 Coupe
Good information thank you. Now I have to locate a complete set in good shape.
Old 02-06-2013, 03:53 PM
  #80
AMGDave's Avatar
300D, 500E, E420
Warning... the info above only takes care of the lug bolt issue. You still need to determine if the width & offset is correct for the 124.
Based on the info at this link:
http://www.alloywheelsdirect.net/mer...segin_wheel_78
...I don't think these will fit a W124 chassis without spacers, at least up front... or it will be a very, very close fit between the tire and the strut tube. Looks like a 5mm hubcentric spacer should work up front. You'll need to roll the fender lips front & rear too. Otherwise I think they will work...
Old 02-06-2013, 03:59 PM
  #81
XJguy's Avatar
94 E320 Coupe
Thanks again, the ones in the link are the 18" variety, they also came in 17" which I think is the ideal size for this chassis. But I am not sure about fitment either. I do not want to roll any fenders.
Old 02-07-2013, 11:15 AM
  #82
AMGDave's Avatar
300D, 500E, E420
Yep, this style is also available in 17x7.5 ET46:
http://www.alloywheelsdirect.net/mer...egin_wheel_906
Use a 225-45-17 tire, and I believe those will fit with zero modifications, no spacers required, and you shouldn't have issues with rubbing. They're available new for approx $410/ea from MBFL. The wheel will be very close to the strut tube but there should still be a few mm air gap.
I have no idea how common these are, or if you'll be able to locate a used set. Keep in mind that if used wheels need to be repaired or refinished (can be $100-$200 each!), the total cost can quickly skyrocket... making new ones look like a relatively good deal. Ideally you would find a mint set locally but that doesn't always happen...
Old 02-07-2013, 07:03 PM
  #83
XJguy's Avatar
94 E320 Coupe
Thank you for the confirmation. They are not all that common but generally disliked, however I think they would look good on a W124. But I dont want spend as much on a set as a set of AMG Aero's would cost, so Ill have to shop around.
Old 02-07-2013, 09:23 PM
  #84
stormtigers's Avatar
88 W124 300CE
Thanks DAVE - you saved me typing that in.
edcarls make a note matey - use 12mm in a 14mm bolt hole at your own risk.
The ball seat is bigger by 2mm which mean the bolt will seat but not fully !
There will be an area around the circumference of un-filled "ball seat" for want of a better phrase.
That can lead to movement during the tightening process and have a bolt that is incorrectly seated with a bias towards one side.
It is not a good practice at all !
Old 02-07-2013, 09:29 PM
  #85
88 W124 300CE
Have a look at Saijin's coupe. Those wheels work pretty darn well and they are in the "monoblock" style in a fashion.
My old Coupe wheels were 10 Spoke MB C Class.
But yet to be revealed, cause they haven't arrived yet, some very nice periodic retro's - very rare and look great IMO.
But no - I am not sharing on this thread.......
Old 02-15-2013, 05:59 PM
  #86
rickruan's Avatar
mercedes benz 1995 e320
18" rims and 225/40 Fr 245/40 Rear
I bought my 1995 MB E320 with 84000 miles on it in april 2011 and have been very happy with it. Two weeks ago I replaced the original 15" Front & Rear alloy wheels ET44 eight hole rims
http://www.alloywheelsdirect.net/mer...ole_wheel_1229
with a set from a CLS550 18" rims and 225/40 Fr 245/45 Rear
Front alloy wheels: 18x8.5" ET28
http://www.alloywheelsdirect.net/mer...poke_wheel_737
I had to have the rear wheel fender rolled, it was touching it whenever I hit a bump, after that, no more touching, scraping or any sort of problem, happy with the wheel & tire combo.
Helpful Links for wheels
Tirerack links where you can specify the make year and model and they will give you tire sizes with all the info including offsets
http://www.tirerack.com/wheels/resul...95&autoModClar=
alloywheelsdirect to know what your current wheel size width and offset
http://www.alloywheelsdirect.net/mercedes_alloy_wheels
Old 03-01-2013, 12:24 PM
  #87
Cruising's Avatar
1990 300CE
The following 2 users liked this post by Cruising:
aphx01 (04-29-2019), E36T (01-08-2017)
Old 05-07-2013, 12:31 AM
  #88
XJguy's Avatar
94 E320 Coupe
Anyone know if 18x8.5 ET 44 AMG wheels will fit the W124?
Old 05-07-2013, 04:09 AM
  #89
BlackStar Stig's Avatar
W124 230E 1990
I know this, you will need atleast 9mm spacers at the front to get 1mm clearance to the strut.
Old 05-08-2013, 12:56 AM
  #90
XJguy's Avatar
94 E320 Coupe
Thanks....
How about : PN A2204010802 18" ET44 ?
Old 05-08-2013, 06:04 AM
  #91
W124 230E 1990
Thanks....
They are still 8,5" in with and ET44. So you will still be hitting the strut without those spacers... But having those spacers I think they will fit.
Old 05-08-2013, 12:17 PM
  #92
XJguy's Avatar
94 E320 Coupe
Thanks, but will I then have fender rubbing?
Old 05-08-2013, 12:55 PM
  #93
W124 230E 1990
It depends on ride height and the tire size you choose. But with 215/40-18" up front you should run clear of rubbing, unless you slam the car to the ground. And even if you should slam the car and get some rubbing it will be so minor that it is easily fixed with a fender roller or the AMG fender spacerkit installed.
Old 05-08-2013, 05:04 PM
  #94
XJguy's Avatar
94 E320 Coupe
Sounds good I appreciate the help. Seems my fenders are already rolled....since inner lip goes up, but I have stock wheels, go figure.
Old 05-11-2013, 04:12 PM
  #95
XJguy's Avatar
94 E320 Coupe
Can anyone identify these wheels
Old 05-14-2013, 08:23 PM
  #96
AMGDave's Avatar
300D, 500E, E420
Looks like Carlsson somethingorothers to me....
Old 05-14-2013, 09:10 PM
  #97
XJguy's Avatar
94 E320 Coupe
Thanks, yes they are the Carlsson 1/12.
Old 05-14-2013, 10:06 PM
  #98
XJguy's Avatar
94 E320 Coupe
Exclamation
Okay I have the measurements of the stock wheels and tires vs. the W220 S / CL 600 17" wheels. Can someone tell me of its acceptable and will fit?
Old 05-26-2013, 01:42 PM
  #99
XJguy's Avatar
94 E320 Coupe
AMG mono IIs rear is 17x8.5 et30 and front is 17x7.5 et35, will these work on a C124? Thanks
Old 05-28-2013, 01:15 PM
  #100
AMGDave's Avatar
300D, 500E, E420
Fronts should be ok. You'll need to roll the fender lips on the rears though.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: definitive wheel fitment guide for w124 pdf
